Event triggered manually, cannot re run for x minutes
  • S-F
    This is not the case for a manually triggered event that's called from another event. The cannot re-run for is not respected. I filed a bug report on this a little over a year ago. I'm sure nobody at HST cares. I'm not sure if it's the same for a script though.
  • mikee123
    If I trigger an event via a script, for example
    hs.TriggerEvent("AC close bedroom windows")
    can I specify run only if event conditions are true ?
    Also, if I trigger a mannually triggered event with an And if condition from a script, will that only run if the And if condition is met ?
  • mikee123
    Ok thats what I was hoping for. Cheers
  • rprade
    Originally posted by mikee123 View Post
    I have an event, which triggerd manually. I have ticked the option not to re run for 5 minutes. I am going to use a script to trigger the event. What happens if I trigger the event within these 5 minutes ? I do not want it to run if its within the 5 minutes, but not sure if thats going to be evaluated if the event is triggered by a script
  • mikee123
    started a topic Event triggered manually, cannot re run for x minutes
