I have an event, which triggerd manually. I have ticked the option not to re run for 5 minutes. I am going to use a script to trigger the event. What happens if I trigger the event within these 5 minutes ? I do not want it to run if its within the 5 minutes, but not sure if thats going to be evaluated if the event is triggered by a script
Event triggered manually, cannot re run for x minutes
Originally posted by mikee123 View PostI have an event, which triggerd manually. I have ticked the option not to re run for 5 minutes. I am going to use a script to trigger the event. What happens if I trigger the event within these 5 minutes ? I do not want it to run if its within the 5 minutes, but not sure if thats going to be evaluated if the event is triggered by a scriptHS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
If I trigger an event via a script, for example
hs.TriggerEvent("AC close bedroom windows")
can I specify run only if event conditions are true ?
Also, if I trigger a mannually triggered event with an And if condition from a script, will that only run if the And if condition is met ?Last edited by mikee123; June 26, 2018, 10:36 AM.
This is not the case for a manually triggered event that's called from another event. The cannot re-run for is not respected. I filed a bug report on this a little over a year ago. I'm sure nobody at HST cares. I'm not sure if it's the same for a script though.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostThis is not the case for a manually triggered event that's called from another event. The cannot re-run for is not respected. I filed a bug report on this a little over a year ago. I'm sure nobody at HST cares. I'm not sure if it's the same for a script though.
Just to confirm what you are reporting, I set up these two Events. Test 2 cannot be rerun for 1 minute.
I manually triggered test 1 at 5:41:54 and test 2 ran. I ran test 1 a second time within 5 seconds at 5:42:04 and test 2 did not run. These log entries are in reverse chronological order, but they confirm that test 2 only ran once, the first time event 1 was run. After a couple of minutes at 5:44:21 test 1 would run test 2 test 2 again.
Jun-26 5:44:26 PM Event Deleting event after run: "Delayed Actions Vanity Lights (Delayed Action)"
Jun-26 5:44:26 PM Event Event Trigger "Delayed Actions Vanity Lights (Delayed Action)"
Jun-26 5:44:21 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-26 5:44:21 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-26 5:44:21 PM Event Event HomeSeer Demo Test 1 triggered by the event page 'Run' button.
Jun-26 5:42:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-26 5:42:04 PM Event Event HomeSeer Demo Test 1 triggered by the event page 'Run' button.
Jun-26 5:41:59 PM Event Deleting event after run: "Delayed Actions Vanity Lights (Delayed Action)"
Jun-26 5:41:59 PM Event Event Trigger "Delayed Actions Vanity Lights (Delayed Action)"
Jun-26 5:41:57 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-26 5:41:57 PM Event Event HomeSeer Demo Test 1 triggered by the event page 'Run' button.
Jun-26 5:41:54 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-26 5:41:54 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-26 5:41:54 PM Event Event HomeSeer Demo Test 1 triggered by the event page 'Run' button.
It appears to be working as I described here. How is it not working for you?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Odd. I have a situation that occurs every single day where this isn't the case. When I get home as determined by my phone connecting to the wi-fry network a manually run event is called. Then it is called again when I enter my PIN at the door. Without fail the even runs twice. This happens EVERY SINGLE DAY! The secondary event wakes my PC and fires up the browser and a few other applications. By the time I sit down at the computer there are two instances of all of these applications running. It's a PITA. It wasn't an issue with my older PC as it booted faster so by the time I was entering my PIN at the door it would already be up and running and a condition of the secondary event is that my PC not be running but the newer PC is a little more industrial/commercial and takes a lot longer to boot.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
For me the cannot re run for x minutes does not work. Sometimes it seems to stop execution of the event, other times its still running. I am trying to find a pattern, so far I havent. After the event triggered, (I have a cannot re run for 10 minutes), I triggered a manual run. It did not run. I clicked run again, and it triggered. That was within 2 minutes of the event running. Before that I noticed, the event run every 3 minutes, even though cannot run for 10 minutes is selected. The event is triggered by a script command: hs.TriggerEvent("AC close bedroom windows") every 3 minutes
Jun-30 22:10:38 Event Event Trigger "Notifications TTS AC close bedroom windows"
Jun-30 22:10:38 Event Event Notifications TTS AC close bedroom windows triggered by the event page 'Run' button.
Jun-30 22:10:26 Event Event Notifications AC close bedroom windows triggered by the event page 'Run' button.
Jun-30 22:07:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 22:04:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 22:01:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 21:58:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 21:55:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 21:52:27 Event Event Trigger "Notifications AC close bedroom windows"
Jun-30 6:20:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:19:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:19:04 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-30 6:18:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:17:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:16:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:15:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:14:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:14:04 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-30 6:13:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:12:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:11:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:10:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:09:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:09:04 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-30 6:08:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:07:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:06:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:05:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:04:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:04:04 PM Event Event Trigger "HomeSeer Demo Test 2"
Jun-30 6:03:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:02:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:01:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 6:00:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 5:59:04 PM Event Event Trigger "HomeSeer Demo Test 1"
Jun-30 5:59:04 PM Event Event Trigger "HomeSeer Demo Test 2"
Originally posted by zwolfpack View PostCould it be that triggering from scripting function works differently that triggering solely thru event engine?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
There should be an easy workaround, for the time being at least, I have created another event which runs the event originally triggered by the script. The script does run the event which runs the original event. That way, the event which cannot re run for x minutes is triggered by another event. So that should work...
