Hi All,
Can I get someone to help me figure out why my temperature variables are not showing as 1 decimal place.
Not a scripter - just a copy, change, hunt and peck person trying to scrape by.
I wanted to create a temperature rate change per hour. I use UltraWeatherWU3 but WU does not provide a rate per hour variable. S1 refers to the Station 1 temperature (which does show to 1 decimal). I created two variables by copying that device. They immediately show 1 decimal just like the original. But then when I run the script these variables come back as integer values.
' Set the value of S1 Rate to 4x the change between the just changed S1 Temp and the stored prior S1 Temp
' Delta is the Difference between S1 (431) and prior S1 (635)
' Multiply by 4 since I am using 15 minute refresh in UltraWeatherWU
' After Rate is calculated then store the new S1 into Prior S1
Dim Delta
Dim Rate
Delta = hs.Devicevalue(431) - hs.Devicevalue(635)
Rate = 4 * Delta
hs.SetDeviceValueByRef(636, Rate, True)
hs.SetDeviceValueByRef(635, hs.devicevalue(431), True)
hs.WriteLog("WHF", "S1 Rate" & hs.devicevalue(636))
hs.WriteLog("WHF", "New S1 Prior " & hs.devicevalue(635))
end sub
Thanks in advance for any help. No laughing
Vector
Dim Delta
Dim Rate
Rate = 4 * Delta
end sub
Vector
