hs.ping() does not work
  • hs.ping() does not work
    when running the below code I get this error
    Compiling script /usr/local/HomeSeer/scripts/Occupancy_Ping.cs: {interactive}(15,25): error CS1061: Type `Scheduler.hsapplication' does not contain a definition for `Ping' and no extension method `Ping' of type `Scheduler.hsapplication' could be found (are you missing a using directive or an assembly reference?)
    What could be the issue here? i have a more complicated script that doesn't use hs.Ping() and it works ok.
    using System;
    object Main(object[] Parms) {
        Int32 Pingable = hs.Ping(Parms[0]);
        if ( Pingable == 1 ) {
            hs.CounterIncrement("OccupancyPing");
        } else {
            hs.CounterReset("OccupancyPing");
        return 0;
    I use this vb.net script routinely and it works fine.
        Public Sub Main(ByVal Parms As Object)
            Dim Google As String = "8.8.8.8"
            Dim intR As Integer
        intR = hs.Ping(Google)
        If intR = 0 Then
             hs.WriteLog ("Internet", "OK")
        Else
             hs.WriteLog ("Internet", "??")
        End If
        End Sub
    What is the form of your 'Params[0]'? It needs to be a string containing the IP address of the site you want to check.
    HS3 Pro Edition 3.0.0.548
      I'll try that, I'm starting to learn C# so don't want to confuse myself with VB.
      The Parms[0] is just the first array element that's passed from the parameters field on the event.
      I've previously used Parms[0].ToString() to the same results.
      Could it be possible that the Ping function isn't exposed properly to C#? I'll try your method when I get home.
        I would expect hs.ping(Parms[0].ToString) to work if Parms(0) is a valid IP address.
          It seems that hs.Ping() just doesn't work in C#, dumb.
          I did re-purpose your script, so thank you!
          Public Sub Main(Optional ByVal Parms As String = "")
              Dim intR As Integer
              Integer intR = hs.Ping(Parms)
              If intR = 0 Then
              Else
              End If
          End Sub
