Getting Cast from 'String' to type 'Integer' is not valid
  • Getting Cast from 'String' to type 'Integer' is not valid
    Hi
    I know I am missing some simple . I have the following very basic script running on Troller Z Raspberry PI
    sub Main(parm as object)
        hs.WriteLog("Node 22 Device Q69", "Querying")
    hs.speak("Your Hot tub has a temperature of "   )
    hs.speak(hs.DeviceValue("Q69"))
    End Sub
    the ref to the device value throws the following error:
    Error 1 Running script /usr/local/HomeSeer/scripts/Startup.vb :Exception has been thrown by the target of an invocation.Cast from 'String' to type 'Integer' is not valid.
    The device is a z wave at node 22 with a reference of code of Q69
    I tried using cstr to no avail. the value of Q69 is a temperature ie current value is 103.1 F
    Thanks for any help
    hs.DeviceValue now uses the Reference ID for a device. This will be in the format hs.DeviceValue(1234) where 1234 is the reference number for Q69. This only outputs an Integer so would return 103
    You should be using hs.devicevalueEx(1234) which will give you a double Integer output i.e. 103.1
    Jon
      Originally posted by wkrasner View Post
      Hi
      End Sub
      Thanks for any help
      The parameter for DeviceValue is the device reference id, not the address code. The id is an integer hence the error message.
      Also you should really use hs.DeviceValueEx(dvRef) because hs.DeviceValue(dvRef) returns an integer so decimal values will be truncated.
      Steve
        Jon00 replied while I was typing
          Thanks guys worked great
