Hs.devicestring problem
  • Hs.devicestring problem
    I’m having a senior moment
    In immediate window
    &hs.speak hs.Devicevalue(1042)
    Works as expected
    Log shows
    TTS speak():1
    But
    &hs.speak hs.DeviceString(1042)
    Doesn’t say anything
    Log shows
    TTS speak():
    Status screen shows a string of “clean”
    Probably a simple thing I’m not seeing
    Andrew B.
    hs.Speak(hs.DeviceString(1024)) perhaps?
    Don
      Do you have a device value/status pair that links "clean" to the value of 1?
      The device management screen will display the status text if the device string is empty. Look at the advanced tab of the device. That will display both the status and the device string.
      Have you tried using the replacement variable? &hs.speak $$DSR:1042:?
      HS3 Pro Edition 3.0.0.548
        AFAIK, replacement variables do not work inside of scripts/immediate script commands.
          I think you are correct. I guess you'd need to use the Speak action of an event rather than an immediate script.
          I don't know of a way to speak a device status using a script.
            This works:
            &hs.speak(hs.CAPIGetStatus(2776).Status)
              Impressive!
              Using CAPI to retrieve a device status would do Rube Goldberg proud.
                Impressive!
                Lol
                  Thx... not sure why the string is blank... see attached screenshots
                  Andrew B.
                    Pretty normal that the string is blank. Most devices show value and status.
                      I guess I was confusing status with devicestring...
                      So... how can I have it speak the status? (“On base”, “cleaning”, etc)
                      Andrew B.
                        I posted a way to do so earlier in the thread in post #6.
                          Thank you very much.... !! that works well for what i was looking for.
                          Andrew B.
                            I created a multi purpose function for this
                            You can use  $DEVICESTRING( DeviceRef)$ in the string and send it to this function.
                            You will get the device string back even if this is a value pair.
                            ' REPLACEMENT VARIABLE
                            ' Using replacement values
                            ' Usage : (String in)
                            '  STRINGS REPLACED
                            '  $DEVICESTRING(RefID of device)$
                            Function ReplacementVariable(ByVal TestString As String) As String
                             Dim CheckString = Instr(TestString, "$DEVICESTRING(")
                             Dim   temp2     = Replace(TestString, "$DEVICESTRING(", "")
                                Dim ThisDevID   = Mid(temp2, CheckString, Instr(temp2, ")$") - CheckString )
                                CheckString     = "$DEVICESTRING(" & ThisDevID & ")$"
                             If (hs.DeviceString(ThisDevID) = "") Then
                               ' In case that the device has no device string set
                               ' then try to get de VSP value-string pair.
                                 Dim VSPstring
                                 Dim DevRef  = CInt(ThisDevID)
                                 Dim Value   = hs.DeviceValue(DevRef)
                                 Dim VSPType = 1  ' 0 = Status - Control
                                ' 1 = Status
                                ' 2 = Control
                               VSPString = hs.DeviceVSP_GetStatus(DevRef, Value, VSPType)
                               temp2 = Replace(TestString, CheckString, VSPString )
                             Else
                                  temp2 = Replace(TestString, CheckString, hs.DeviceString(ThisDevID) )
                             End If
                             Return temp2
                            End Function
