Help with C# script in Linux
  • Help with C# script in Linux
    Newb here, coming from ISY. I'm looking to write a quick little script in C# that will get the value of two devices, average them, and then set that value to one virtual device.
    Ex: Insteon Bulb "A" set to a value of 10, Insteon Bulb "B" set to a value of 50, then set Virtual Bulb 1 to a value of (A+B)/2 (30). I jdon't know what strings to call.
    Any help is appreciated.
    Also, is there anywhere I can find a bunch of "sample" C# scripts (specific to Homeseer in Linux) I can play with? Thanks in advance.
    Any reason you want to go with c# instead of vb.net? Lots of examples for vb, but very few for c#.
      From what I understand C# is much faster in Linux. If that is not the case (there is no appreciable difference), then sure, I'll do vb.net. (still a newb at this )
        I don't know if there would be much difference and if there was, whether it's significant. From what I understand, both would be .NET based and therefore processed by Mono either way.
