HS3 Scripting - CAPI - Set Device to same status as an other device
  • Techn0
    Something like this:
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev, false, CStr(hs.DeviceValue(sourceDev)), false, true))
    Thanks.
    Works for the setting the value. I will give the IF statement a try tomorrow :-)
  • sparkman
  • HS3 Scripting - CAPI - Set Device to same status as an other device
    Hi All,
    I don't seem to be getting very far for what i thought would be a simple task.
    Setting a device to be the same value as an other. A Radiator Heating set point to be the same as a VSTAT value.
    If the value of Device with Ref 300 does not equal the value of device with Ref 230, then set value of the device with Ref 300 to the same as that as the device with Ref 230.
    I understand CAPI needs to be used so that the command is sent over the Z-wave network to device.
