Send a variable value into a simple line function hs.GetURL
  • Send a variable value into a simple line function hs.GetURL
    hi,
    What I want to send is :
    This work
    nhs.GetURL("IPADRESS","?message=Anything&intensity=10&speed= 40&static=0",TRUE,port)
    but not this
    nhs.GetURL("IPADRESS","?message=$$DVR:9064&intensity=10&spee d=40&static=0",TRUE,port)
    Is there a way to make this work without creating a script to parse device value into this one line?
    Use:
    hs.GetURL("IPADRESS","?message=" & hs.devicevalue(9064) &"&intensity=10&spee d=40&static=0",TRUE,port)
    As you found out, you can't use replacement variables within script statements, so use the equivalent scripting call instead.
      Originally posted by sparkman View Post
      Use:
      that work 100% thanks a lot !!
