Create script for Opening Abus Wapploxx Doorlock?
  • Create script for Opening Abus Wapploxx Doorlock?
    Hello. Perhaps someone is able to help me for writing a script that is able to open my doorlock.
    there is an app for abus wapploxx but no available api for customers.
    I used wireshark to find out how the central box webinterface communicates.
    this is http command for login in browser:
    http://192.168.0.76/login.cgi?ts=154...4&Action=Start
    this the command for open door as long as you typed in same window as the login before:
    http://192.168.0.76/setRemoteAccess....4&Action=Start
    when i create an event with single-line script hs.urlaction for login and then another with the opening command, its doesnt work, cause of not staying logged in.
    regards
    it's really not an elegant solution, but at least it works.
    i simply start the application firefox 2 times per event with the links as parameters at intervals of a few seconds.
    as I said, absolutely unprofessional solution.
      I'm not sure if the command works any more but you could try hs.GetURLIE if you are running HS3 on Windows. That should also cache the user/password as it uses Internet Explorer.
      &hs.GetURLIE("http://192.168.0.76/login.cgi?ts=1549998004625&Source=Webpage&Username=dXNlcm5hbWUNCg==&Password=cGFzc3dvcmQNCg==&LoxxId=4&Action=Start",TRUE)
      If it errors, it has still not been fixed.
      Jon
        Hey jon,
        thanks for that. the code works! much better than the stupid way with launching browser.
        i made a second line with the other link and the door opens like magic :-)
        regards
