Stuck at comparing date time.
  • Stuck at comparing date time.
    //SOLVED
    Hello guys,
    I'm stuck at comparing after my api change the date from 2019/11/12 to 2191112
    I'm getting errors that it can't compare..
    How can i solve this.
    This is what i had and need:
    Dim StartDate As Date = obj.Item("MYDEVICEDATE").ToString 'Start Date
    Dim CompareDate As Date = Now.Date 'Todays Date
    Dim result as integer = Datetime.Compare(startdate, Comparedate)
    JSON Exception: Conversion from string "20191112" to type 'Date' is not valid.
    So then i tried this just to see if it works :
    dim timr2 = "20191112"
    Dim StartDate As String = timr2
    Dim CompareDate As string = DateTime.Now.ToString("yyyyMMdd") 'Todays Date
    hs.writelog ("look",result)
    end sub
    Error 1 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\10101010.vb :Exception has been thrown by the target of an invocation.Conversion from string "20191112" to type 'Date' is not valid.
    Regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 3.0.0.500 on windows 7 ultimate X64 on hp quadcore laptop 8 GB.
        Dim timr2 As String = obj.Item("MYDEVICEDATE").ToString
        Dim StartDate As Date = Date.ParseExact(timr2, "yyyyMMdd",System.Globalization.DateTimeFormatInfo.InvariantInfo)
        Dim CompareDate As Date = DateTime.Now
        Dim result as integer = Datetime.Compare(StartDate, CompareDate)
    End Sub
    Jon
      One other problem I see that can muck up your compare: You are comparing the timr2 date, which has no hours or minutes specified, with "now()" which does. I suspect Date() would work better (as used in the OP)
        Hi jon,
        thanks for the reply,
        i did try the code but and change it to this, it works but i get the wrong result
        Dim StartDate As String = obj.Item("MYDATE").ToString
        Dim StartDate2 As Date = Date.ParseExact(StartDate, "yyyyMMdd",System.Globalization.DateTimeFormatInfo.Invar iant Info)
        Dim CompareDate As Date = Date.today
        hs.writelog ("comparedate",comparedate)
        hs.writelog ("startdate2",Startdate2)
        Dim result as integer = Datetime.Compare(StartDate2, CompareDate)
        I get result = 1, i dont know why
        the inputdate = 20190519
        and date today = 20190218
        Originally posted by jon00 View Post
        End Sub
          Change the second to last line to:
          Dim Result As Integer = (StartDate - CompareDate).Days
          Jon
            thanks again for your help, that did do it
