A way to remove PED named data?
  • A way to remove PED named data?
    Hi,
    this is data created from another plugin, wich i can't remove. When i start Homeseer i got waring about serialization etc.
    . I would like to remove the second and third entries :
    xxxxxtriggerruntiemdata_133143993854: System.Byte[]
    xxxxxriggerruntimedata_133143993854: System.Byte[]
    I have seen this :
    https://help.homeseer.com/help/HS3SD...m#.removenamed
    and tried to do a script but I do not understand how a scripts would be constructed for this to work. I have no scripts skill.
    Can someone put me in the right direction to remove those plugin extra data entries?
    thanks.
    Matt
    Just a up maybe this thread got lost .
      Using C# script - save this in a file with .cs extension in C:\Program Files (x86)\HomeSeer HS3\scripts folder.
      The script gets device using its refID (i.e. 20 in my example), prints all named PEDs, then calls RemoveNamed - you need to put your names there.
      public int Main(Object[] args)
        int dvRef = 20;
        Scheduler.Classes.DeviceClass dv = (Scheduler.Classes.DeviceClass)hs.GetDeviceByRef(dvRef);
        hs.WriteLog("info", dv.get_Name(null));
        PlugExtraData.clsPlugExtraData EDO = dv.get_PlugExtraData_Get(hs);
        foreach(string name in EDO.GetNamedKeys())
            hs.WriteLog("info", name);
        EDO.RemoveNamed("ak_checkconditionssatisfiedtriggertimercallback");
        EDO.RemoveNamed("ak_currenttab");
        hs.SaveEventsDevices();
        return 0;
        Hi, alexbk66 , thanks for this !!
        Can i run c# under linux?
          Why not? You are using mono anyways. C# is actually better and faster under linux, for VB you need extra assemblies.
            Thanks it worked !!
            I was getting error at the beginning because i wrote ''Main'' in the function field. But now it works haha...
              NP
