Scipt to pull data from the new WU API
  • Scipt to pull data from the new WU API
    Here is the script I am using to pull data from the new WU API. This only works if you are also sending WU data and they have given you a new key for the new API.
    I don't expect that this will work exactly as is for anyone else, but it does give you a starting place. Sorry that it is not commented better.
    Imports System.Web.Script.Serialization
    Const Fname As String  = "WeatherForecast.vb"          ' this file name
    Const Lcolor As String = "#ffaa56"                     ' log color for normal
    Dim json As New JavaScriptSerializer
        Try
            Dim DataRaw As String = hs.geturl ("https://api.weather.com","/v3/wx/forecast/daily/5day?geocode=your_latitude,your_longitude&units=e&language=en-US&format=json&apiKey=your_key",FALSE ,"80")
         if left(DataRaw,5) = "ERROR" then
            hs.WriteLogDetail(Fname,DataRaw, "#FF0000", 2,Fname & ":Main",1)
         else
            Dim jData As WU = json.Deserialize(Of WU)(DataRaw)
            UpdateNlog("w100",0,jData.dayOfWeek(0),0)
            UpdateNlog("w110",jData.temperatureMin(0),"",0)
            UpdateNlog("w140",jData.daypart(0).iconCode(1),jData.daypart(0).narrative(1),0)
            if IsNothing(jData.temperatureMax(0)) then              ' WU sends null when the day forcast has already passed
               'UpdateNlog("w120",-99,"",1)
            else
               UpdateNlog("w120",jData.temperatureMax(0),"",0)
            end if
            if IsNothing(jData.daypart(0).iconCode(0)) then         ' Use the night icon if the day one is no longer being sent
               UpdateNlog("w130",jData.daypart(0).iconCode(1),jData.daypart(0).narrative(1),0)
               UpdateNlog("w105",2,"",0)                                                      ' night forecast
            else
               UpdateNlog("w130",jData.daypart(0).iconCode(0),jData.daypart(0).narrative(0),0)
               UpdateNlog("w105",1,"",0)                                                      ' day forecast
            end if
            UpdateNlog("w101",0,jData.dayOfWeek(1),0)
            UpdateNlog("w111",jData.temperatureMin(1),"",0)
            UpdateNlog("w121",jData.temperatureMax(1),"",0)
            UpdateNlog("w131",jData.daypart(0).iconCode(2),jData.daypart(0).narrative(2),0)
            UpdateNlog("w141",jData.daypart(0).iconCode(3),jData.daypart(0).narrative(3),0)
            UpdateNlog("w102",0,jData.dayOfWeek(2),0)
            UpdateNlog("w112",jData.temperatureMin(2),"",0)
            UpdateNlog("w122",jData.temperatureMax(2),"",0)
            UpdateNlog("w132",jData.daypart(0).iconCode(4),jData.daypart(0).narrative(4),0)
            UpdateNlog("w142",jData.daypart(0).iconCode(5),jData.daypart(0).narrative(5),0)
            UpdateNlog("w103",0,jData.dayOfWeek(3),0)
            UpdateNlog("w113",jData.temperatureMin(3),"",0)
            UpdateNlog("w123",jData.temperatureMax(3),"",0)
            UpdateNlog("w133",jData.daypart(0).iconCode(6),jData.daypart(0).narrative(6),0)
            UpdateNlog("w143",jData.daypart(0).iconCode(7),jData.daypart(0).narrative(7),0)
            UpdateNlog("w104",0,jData.dayOfWeek(4),0)
            UpdateNlog("w114",jData.temperatureMin(4),"",0)
            UpdateNlog("w124",jData.temperatureMax(4),"",0)
            UpdateNlog("w134",jData.daypart(0).iconCode(8),jData.daypart(0).narrative(8),0)
            UpdateNlog("w144",jData.daypart(0).iconCode(9),jData.daypart(0).narrative(9),0)
         end if
    Catch Ex As Exception
        hs.WriteLogDetail(Fname,Ex.Message, "#FF0000", 2,Fname & ":Main",1)
        End Try
    End Sub
        Public Class Daypart
            Public Property cloudCover As Integer?()
            Public Property dayOrNight As String()
            Public Property daypartName As String()
            Public Property iconCode As Integer?()
            Public Property iconCodeExtend As Integer?()
            Public Property narrative As String()
            Public Property precipChance As Integer?()
            Public Property precipType As String()
            Public Property qpf As Double?()
            Public Property qpfSnow As Double?()
            Public Property qualifierCode As Object()
            Public Property qualifierPhrase As Object()
            Public Property relativeHumidity As Integer?()
            Public Property snowRange As String()
            Public Property temperature As Integer?()
            Public Property temperatureHeatIndex As Integer?()
            Public Property temperatureWindChill As Integer?()
            Public Property thunderCategory As String()
            Public Property thunderIndex As Integer?()
            Public Property uvDescription As String()
            Public Property uvIndex As Integer?()
            Public Property windDirection As Integer?()
            Public Property windDirectionCardinal As String()
            Public Property windPhrase As String()
            Public Property windSpeed As Integer?()
            Public Property wxPhraseLong As String()
            Public Property wxPhraseShort As String()
        End Class
        Public Class WU
            Public Property dayOfWeek As String()
            Public Property expirationTimeUtc As Integer()
            Public Property moonPhase As String()
            Public Property moonPhaseCode As String()
            Public Property moonPhaseDay As Integer?()
            Public Property moonriseTimeLocal As Object()
            Public Property moonriseTimeUtc As Integer?()
            Public Property moonsetTimeLocal As Object()
            Public Property moonsetTimeUtc As Integer?()
            Public Property sunriseTimeLocal As DateTime()
            Public Property sunriseTimeUtc As Integer?()
            Public Property sunsetTimeLocal As DateTime()
            Public Property sunsetTimeUtc As Integer?()
            Public Property temperatureMax As Integer?()
            Public Property temperatureMin As Integer?()
            Public Property validTimeLocal As DateTime()
            Public Property validTimeUtc As Integer?()
            Public Property daypart As Daypart()
        End Class
    Sub UpdateNlog (HDcode As String, Dvalue As Double, Dstr as String, Always as Integer) ' this routine updates a device and logs it if
        ' it changed and if logging is turned on for the device or if always is set
      Try
        dim Dref    = hs.GetDeviceRef(HDcode)                                   ' get the reference to the device based on the house/device code
        dim dv      = hs.GetDeviceByRef(Dref)                                   ' get device settings
        dim Du      = hs.GetDeviceByRef(Dref)                                   ' get device data
        dim Dstring = hs.DeviceVSP_GetStatus(Dref, Dvalue, 1)                   ' get the string
        hs.SetDeviceValueByRef (Dref,Dvalue,TRUE)                               ' update the device value
        if Dstr > "" then
           hs.SetDeviceString (Dref,Dstr,true)                                  ' update the device string if provided
           Dstring = Dstr                                                       ' for the log
        end if
        if (dv.MISC_Check(hs, Enums.dvMISC.NO_LOG) = 0) or (Always = 1) then    ' should it be logged?
           hs.WriteLogDetail(Fname,Du.Location(hs) & " " & Du.name(hs) & " set to: " & Dstring, Lcolor, 9,Fname,1)
        end if
          hs.WriteLogDetail(Fname,Ex.Message, "#FF0000", 1,Fname & ":UpdateNlog",9)
    End Try
    end sub
    You will have to create the devices that the script expects.
    Here's one example. (Only the first few icons shown)
    Great, thanks for posting. Was planning on writing one myself as it sounds like it will take Jeff a while to update WeatherXML plugin, so it's nice not to have to do that!
      One of the things I'm looking for is forecast precipitation amounts. I should be able to populate a device for that like this, correct?:
       UpdateNlog("w999",0,jData.qpf(x),0)
      where x is 0 through 5 for the different days?
      Thanks again!
        Actually, I suspect that you would want:
        UpdateNlog("w999",jData.qpf(x),"",0)
          UpdateNlog("w999",jData.qpf(x)."",0)
          Ok, thanks!
            Thanks for posting.
              Thank you for posting .. would it be possible to provide some basic guidance in terms of use. Admittedly i am a newbie but it would be very helpful if I can get this running while HomeSeer WU plugin is getting updated. Thank you in advance for any assistance.
                Sure, I can try. I know it's poorly commented. What in particular did you want to start with?
                  I am looking at this script, to pull data from WU into HS3. I am not very good at scripts, but understand a little. First, will it be possible to retrieve current data like temperature, windspeed and rainfall (which I am going to send to WU from my PWS). I would think they are all the Public Property variables in the script. Not that interested in forecast at this stage, just all the data my PWS is sending to WU.
                  If thats possible, I have a few questions (to start)
                  I will need to create virtual devices for all the data I want to retrieve. I set the house code as per your example.
                  If I only wanted the variables under Public Property, what house/device code would they be ? I think the script only pulls in the forecast or am I wrong ?
                    The script I made only pulls forecast data. I get current condition data directly from my weather station.
                    You would have to use the observations URL to get current data, then you would have to set up different classes for the json decode.
                    /v3/wx/forecast/daily/5day?geocode=your_latitude,your_longitude&units=e&language=e n-US&format=json&apiKey=your_key
                    would change to
                    /v2/pws/observations/current?stationId=your_station_id&format=json&units=e&apiKey =your_key
                    then the "public property" statements would have to change to:
                        Public Class Imperial
                            Public Property temp As Integer
                            Public Property heatIndex As Integer
                            Public Property dewpt As Integer
                            Public Property windChill As Integer
                            Public Property windGust As Integer
                            Public Property pressure As Double
                            Public Property precipRate As Double
                            Public Property precipTotal As Double
                            Public Property elev As Integer
                        End Class
                        Public Class Observation
                            Public Property stationID As String
                            Public Property obsTimeUtc As DateTime
                            Public Property obsTimeLocal As String
                            Public Property neighborhood As String
                            Public Property softwareType As String
                            Public Property country As String
                            Public Property solarRadiation As Object
                            Public Property lon As Double
                            Public Property realtimeFrequency As Object
                            Public Property epoch As Integer
                            Public Property lat As Double
                            Public Property uv As Object
                            Public Property winddir As Integer
                            Public Property humidity As Integer
                            Public Property qcStatus As Integer
                            Public Property imperial As Imperial
                        End Class
                        Public Class WUC
                            Public Property observations As Observation()
                        End Class
                    The HDcode is the HomeSeer House and Device code that you assign to the virtual device that you want to use, under the device configuration tab on the "Code:" row. You pick any code you want. You use that same code in the script to put the correct json value in that device.
                    Add:
                    Dim jcData As WUC = json.Deserialize(Of WU)(DataRaw)
                    If you pick HDcode of "t2" for your current temperature device, then add
                    UpdateNlog("t2",0,jcData.observation.imperial.temp,0)
                    This may not be exactly right (I haven't tried it), but it should get you close enough to work it out
                      Ok, thanks for that. I think I understand. I will change the script, and I hope my weatherstation will arrive before the weekend, then I can set it up, start broadcasting to WU and then test the script
                      could I for example to retrieve humidity also add
                       UpdateNlog("t222",0,jcData.observation.imperial.humidity,0)
                      and the same way for other values in Public Class Observation ?
                        Yes, that should be correct.
                          I am getting this error running the script
                          Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: 'observation' is not a member of 'scriptcode85.VBWrapper.WUC'.
                          Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Type 'JavaScriptSerializer' is not defined.
                          Sep-25 19:12:13 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Namespace or type specified in the Imports 'System.Web.Script.Serialization' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                          Sep-25 19:12:13 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                          Const Fname As String  = "WeatherObserved.vb"          ' this file name
                              Try
                                  Dim DataRaw As String = hs.geturl ("https://api.weather.com","//v2/pws/observations/current?stationId=xxx&format=json&units=e&apiKey =xxx",FALSE ,"80")
                               else
                                 UpdateNlog("O112",0,jcData.observation.imperial.temp,0)
                                 UpdateNlog("O113",0,jcData.observation.imperial.heatIndex,0)
                                 UpdateNlog("O114",0,jcData.observation.imperial.dewpt,0)
                                 UpdateNlog("O115",0,jcData.observation.imperial.windChill,0)
                                 UpdateNlog("O116",0,jcData.observation.imperial.windSpeed,0)
                                 UpdateNlog("O117",0,jcData.observation.imperial.windGust,0)
                                 UpdateNlog("O123",0,jcData.observation.imperial.winddir,0)
                                 UpdateNlog("O118",0,jcData.observation.imperial.pressure,0)
                                 UpdateNlog("O119",0,jcData.observation.imperial.precipRate,0)
                                 UpdateNlog("O120",0,jcData.observation.imperial.precipTotal,0)
                                 UpdateNlog("O121",0,jcData.observation.imperial.elev,0)
                                 UpdateNlog("O122",0,jcData.observation.imperial.humidity,0)
                                 UpdateNlog("O124",0,jcData.observation.imperial.uv,0)
                               end if
                              End Try
                          End Sub
                              End Class
                              End Class
                              Public Class WUC
                              End Class
                            Try
                              if Dstr > "" then
                              end if
                              end if
                          End Try
                          end sub
                            Okay. You were really close. Make these changes and you should be good (I only tested for temperature).
                                    Dim DataRaw As String = hs.geturl ("https://api.weather.com","/v2/pws/observations/current?stationId=xxx&format=json&units=e&apiKey=xxx",FALSE ,"80")
                                    Dim jcData As WUC = json.Deserialize(Of WUC)(DataRaw)
                                   UpdateNlog("O112",jcData.observations(0).imperial.temp,"",0)
                            Repeat the above change for the other 12 update lines, observation changed to observations(0)
                            Also change to remove 0, at the front and add ,"" at the end to put the value in the device value instead of in the device string.
                            (Sorry for steering you wrong...)
                            Let me know if this works or if there are any other problems.
                              There is still a problem, but less so now
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: 'uv' is not a member of 'scriptcode88.VBWrapper.Imperial'.
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: 'humidity' is not a member of 'scriptcode88.VBWrapper.Imperial'.
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: 'winddir' is not a member of 'scriptcode88.VBWrapper.Imperial'.
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Type 'JavaScriptSerializer' is not defined.
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Namespace or type specified in the Imports 'System.Web.Script.Serialization' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                              Sep-25 20:41:22 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\WeatherObserved.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                              I guess the commands for UV, humidity and winddir could have a different spelling maybe ?
                              Not sure about the other errors
                              Here is the script now
                                  Try
                                   else
                                     UpdateNlog("O113",jcData.observations(0).imperial.heatIndex,"",0)
                                     UpdateNlog("O114",jcData.observations(0).imperial.dewpt,"",0)
                                     UpdateNlog("O115",jcData.observations(0).imperial.windChill,"",0)
                                     UpdateNlog("O116",jcData.observations(0).imperial.windSpeed,"",0)
                                     UpdateNlog("O117",jcData.observations(0).imperial.windGust,"",0)
                                     UpdateNlog("O123",jcData.observations(0).imperial.winddir,"",0)
                                     UpdateNlog("O118",jcData.observations(0).imperial.pressure,"",0)
                                     UpdateNlog("O119",jcData.observations(0).imperial.precipRate,"",0)
                                     UpdateNlog("O120",jcData.observations(0).imperial.precipTotal,"",0)
                                     UpdateNlog("O121",jcData.observations(0).imperial.elev,"",0)
                                     UpdateNlog("O122",jcData.observations(0).imperial.humidity,"",0)
                                     UpdateNlog("O124",jcData.observations(0).imperial.uv,"",0)
                                   end if
                                  End Try
                              End Sub
                                  End Class
                                  End Class
                                  Public Class WUC
                                  End Class
                                Try
                                  if Dstr > "" then
                                  end if
                                  end if
                              End Try
                              end sub
