Got it , SOLVED
Hello all,
i don;t know where to start at all..
i did found a lot of scripts for parsing the xml data but i can't get it to work..
here is the url where the data is coming from and how its formatted.
the url is http://192.168.x.x/core/modules
<modules><module id="cccd9a140dxxxx599e066afca56"><vendor_name>Ene5\XS21 0ESMR5.0</vendor_name><vendor_model>Ene5\XSxxxSMR5.0</vendor_model><hardware_version/><firmware_version/><created_date>2019-02-21T16:22:43.123+01:00</created_date><modified_date>2019-04-07T12:28:00.275+02:00</modified_date><deleted_date/><services><electricity_interval_meter id="bd521e53xxx9a662023c5"><measurement log_date="2019-04-07T12:00:00+02:00" unit="Wh" interval="PT300S" directionality="produced" tariff_indicator="nl_offpeak">956.000</measurement><measurement log_date="2019-04-07T12:00:00+02:00" unit="Wh" interval="PT300S" directionality="produced" tariff_indicator="nl_peak">0.000</measurement><measurement log_date="2019-04-07T12:00:00+02:00" unit="Wh" interval="PT300S" directionality="consumed" tariff_indicator="nl_offpeak">0.000</measurement><measurement log_date="2019-04-07T12:00:00+02:00" unit="Wh" interval="PT300S" directionality="consumed" tariff_indicator="nl_peak">0.000</measurement></electricity_interval_meter><electricity_cumulative_meter id="317687xxxx9xx838cba3c92c9"><measurement log_date="2019-04-07T12:25:00+02:00" unit="Wh" directionality="produced" tariff_indicator="nl_offpeak">92572.000</measurement><measurement log_date="2019-04-07T12:25:00+02:00" unit="Wh" directionality="produced" tariff_indicator="nl_peak">186981.000</measurement><measurement log_date="2019-04-07T12:25:00+02:00" unit="Wh" directionality="consumed" tariff_indicator="nl_offpeak">131788.000</measurement><measurement log_date="2019-04-07T12:25:00+02:00" unit="Wh" directionality="consumed" tariff_indicator="nl_peak">96659.000</measurement></electricity_cumulative_meter><electricity_point_meter id="064fd82e2xxxx90c0f26e2c75104"><measurement log_date="2019-04-07T12:27:53+02:00" unit="W" directionality="produced">2422.000</measurement><measurement log_date="2019-04-07T12:27:53+02:00" unit="W" directionality="consumed">0.000</measurement></electricity_point_meter></services><protocols><dsmrmain id="516833c0bb2840bdxxxxx59d8365295b3"><serial>E0047xxxxx47 4 22 718</serial><dsmrmbuses>
</dsmrmbuses></dsmrmain></protocols></module></modules>
this is what i need, only the value's ofcourse.:
like to return in hs.writelog.
right now i have this code ;
and returns like this :
If someone can show me how i can parse this ?
with json its easy but with xml i never done that
regards.
Hello all,
Sub Main(ByVal Parms As String) Dim xmlDoc As New XmlDocument() Dim strdata as String Dim PageXML as String Dim XML_Feed as integer = 1 Dim url = "http://usernm:pass@192.168.1.13" Dim page = hs.GetURL(url,"/core/modules",FALSE,80) hs.WriteLog ("test", page) End Sub
Apr-07 12:55:51 Test Ene5\XS210ESMR5.0 Ene5\XS210ESMR5.0 2019-02-21T16:22:43.123+01:00 2019-04-07T12:55:51.824+02:00 1967.000 0.000 0.000 0.000 93583.000 186981.000 131788.000 96659.000 2495.000 0.000 E0047000047422718
regards.
