OK, let's try this again: Is there a way to mute or unmute a computer's sound card through scripting?
SCRIPTING NOVICE: Mute/Unmute (Take 2)
Try what again? There are no built-in HS scripting commands to do so, but those functions should be accessible by .NET. A Google search found a few ways, but seems to be hit and miss. One option may be the NAudio library: https://github.com/naudio/NAudio. It has way more functionality, than just muting/unmuting but I believe it does have functions for that.HS 3.0.0.548: 1990 Devices 1172 Events
(Sigh) I guess nothing can be easy.
Try what again?
Jim Speiser
Still don't know squat
Originally posted by JimSpy View Post(Sigh) I guess nothing can be easy.
I had posted a much longer message under a similar title, but got no responses. I figure it was too complicated, so I tried simplifying, and got you! (No inferences to be drawn!)
The other option (and likely much simpler) is to use this utility: https://www.nirsoft.net/utils/nircmd.html. You can run external programs through events or scripts. Run it manually first to see if it works on your system.HS 3.0.0.548: 1990 Devices 1172 Events
There's also this one: https://www.nirsoft.net/utils/sound_volume_view.html. It has a GUI, but also a command line interface.HS 3.0.0.548: 1990 Devices 1172 Events
Originally posted by sparkman View PostThere's also this one: https://www.nirsoft.net/utils/sound_volume_view.html. It has a GUI, but also a command line interface.
Function Launch(byVal "C:\Users\Speiser's\Desktop\soundvolumeview\SoundVolumeV iew" As String, byVal "/mute" As String, byVal "" As String, byVal 0 As Integer) As Integer
...but of course that doesn't work.
Jim Speiser
OK, I finally got back around to this. That's going to work. Now, I just have to learn how to call it in a script. Do I use the "Launch" function? And if so, how do I set the parameters? I have it as...
The syntax should be:
Code:Dim x as Integer x = hs.Launch("C:\Users\Speiser's\Desktop\soundvolumeview\SoundVolumeView", "/mute", "" , 0)
Yes, launch will work if you are using a script or you can trigger it direct in an event as well.
Thank you, I'll give it a try.
Jim Speiser
Well, that certainly makes it easier. The online Help file makes it look like it has to be in .vb format.
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
