SCRIPTING NOVICE: Mute/Unmute (Take 2)
    OK, let's try this again: Is there a way to mute or unmute a computer's sound card through scripting?
    Jim Speiser
    35-year veteran of Home Automation
    Still don't know squat
    Try what again? There are no built-in HS scripting commands to do so, but those functions should be accessible by .NET. A Google search found a few ways, but seems to be hit and miss. One option may be the NAudio library: https://github.com/naudio/NAudio. It has way more functionality, than just muting/unmuting but I believe it does have functions for that.
    HS 3.0.0.548: 1990 Devices 1172 Events
    Z-Wave 3.0.1.262: 126 Nodes on one Z-Net
      (Sigh) I guess nothing can be easy.
      Try what again?
      I had posted a much longer message under a similar title, but got no responses. I figure it was too complicated, so I tried simplifying, and got you! (No inferences to be drawn!)
      Jim Speiser
        LOL, must have missed your first message.
        The other option (and likely much simpler) is to use this utility: https://www.nirsoft.net/utils/nircmd.html. You can run external programs through events or scripts. Run it manually first to see if it works on your system.
          There's also this one: https://www.nirsoft.net/utils/sound_volume_view.html. It has a GUI, but also a command line interface.
            OK, I finally got back around to this. That's going to work. Now, I just have to learn how to call it in a script. Do I use the "Launch" function? And if so, how do I set the parameters? I have it as...
            Function Launch(byVal "C:\Users\Speiser's\Desktop\soundvolumeview\SoundVolumeV iew" As String, byVal "/mute" As String, byVal "" As String, byVal 0 As Integer) As Integer
            ...but of course that doesn't work.
            Jim Speiser
              Yes, launch will work if you are using a script or you can trigger it direct in an event as well.
              The syntax should be:
              Dim x as Integer
              x = hs.Launch("C:\Users\Speiser's\Desktop\soundvolumeview\SoundVolumeView", "/mute", "" , 0)
                Dim x as Integer
                Well, that certainly makes it easier. The online Help file makes it look like it has to be in .vb format.
                Thank you, I'll give it a try.
                Jim Speiser
                  You're welcome. It is still in vb format, however, the help file shows how the function is defined within the HS vb libraries/code, not how it is intended to be used.
                  Cheers
                  Al
