Newbie question: How to simply turn on/off a light in a script??
    I can't seem to get this to work. I'm using VBscript, here's the script:
    sub main()
    dvRef = hs.GetDeviceRefByName("Jerry's Office")
    hs.writelog "dvRef", dvRef
    objCAPIControl = hs.CAPIGetSingleControlByUse(77, 2)
    hs.writelog "objCAPIControl", objCAPIControl
    hs.CAPIControlHandler objCAPIControl
    end sub
    The log output is:
    Jun-18 1:08:54 PM Error Running script, script run or compile error in file: C:/Program Files (x86)/HomeSeer HS3/scripts/test.txt5:Invalid procedure call or argument: 'hs.CAPIControlHandler' in line 10 More info: Invalid procedure call or argument: 'hs.CAPIControlHandler'
    Jun-18 1:08:54 PM objCAPIControl HomeSeerAPI.CAPI+CAPIControl
    Jun-18 1:08:54 PM dvRef 77
    Jun-18 1:08:54 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/test.txt
    Jun-18 1:08:54 PM Event Event Trigger "misc Test turn a light off/on by script"
    Jun-18 1:08:54 PM Event Event misc Test turn a light off/on by script triggered by the event page 'Run' button.
    Obviously, the device is found (ref # 77), and I think the CAPI control object is found (CAPI+CAPIControl), though I don't know what CAPI+CAPIControl means. But the call to hs.CAPIControlHandler doesn't work. (Note that in VB script, there's no need for parens here).
    The Device is a UPB light switch, a "UPB Device" imported through UPBSpud. I can control the device normally through the Device page interface.
    Note also that the script interpreter objects to the underscore as an "invalid character" if I try this:
    objCAPIControl = hs.CAPIGetSingleControlByUse(dvRef,ePairControlUse._On)
    ...so I substituted the value for "off" (2, supposedly). Quoting the value as a string doesn't work either.
    I've spent hours trying everything to no avail. Any advice appreciated!
    Jerry
    Current Date/Time: 6/18/2019 1:21:49 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.534
    System Uptime: 0 Days 0 Hours 47 Minutes 42 Seconds
    IP Address: 192.168.1.101
    Number of Devices: 155
    Number of Events: 60
    Available Threads: 200
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed: Windows Defender
    In Virtual Machine: No MFG: dell inc.
    Enabled Plug-Ins
    3.0.6681.34300: UltraCID3
    3.0.0.50: UPBSpud
    3.0.0.36: X10
    I believe you need to use vb.net. I don't think the CAPI functions are compatible with VBS. I'd also recommend taking a look at Ed Tenholder's tenScripting for excellent guidance in implementing CAPI.
      tenScriptAid
      tenholde
        According to what I see, is your scripts name 'test.txt' ??
        rename it to 'test.vb' and try again.
        Blair
        HomeSeer: HS3 Pro | Blue-Iris 4 on Windows10Pro
        | Devices: 832 | Events: 211 |
        Plug-Ins: Z-Wave | RFXCOM | UltraRachio3 | Sonos
        BLLAN | BLLOCK | NetCAM | Global Cache Pro | Blue-Iris4
          The first line of the script will probably need to be changed as well
          to: Public Sub Main(ByVal Parms As Object)
            The whole script is in VBScript format so it'll take more than just renaming it and changing the first line.
              Try this and save it with a .vb extension:
              Sub Main(ByVal Parms as String)
              Dim dvRef as Integer = hs.GetDeviceRefByName("Jerry's Office")
              hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef, false, "On", false, false))
              End Sub
              If that does not work, please post a screen shot of the Status Graphics tab for the device that you are trying to turn on.
                Thanks Unc and Sparkman... indeed, I had to bite the bullet and move the scripts to VB using CAPI. Not for the feint of heart, what a complex interface! All working, finally...
                  As Ed noted earlier, I pointed you to the wrong tool in my earlier post. Although tenScripting is a great help when trying to translate a VBS script to vb.net, tenScriptAid is the tool you want to help construct CAPI commands. It makes it relatively easy - even for the faint of heart.
                    I'm over the hump now, but I'll give it a try next script revision...
                      You could just make Al's example a subroutine and use it everywhere you need the function in a script.
                      Sub ControlLight(ByVal AnyLight as String, ByVal NewSetTo As String)
                      Dim dvRef as Integer = hs.GetDeviceRefByName(AnyLight)
                      hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef, false, NewSetTo, false, false))
                      End Sub
                      To use it:
                      ControlLight("Jerry's Office","On")
                      or
                      ControlLight("Jerry's Office","Off")
                        Thanks, very helpful!
                        jerry
