Trying to setup a mute button for my audio system. The Plugin I'm using doesn't have a built-in mute.
The problem I'm having is I want the mute to be a toggle.
So I need to get the current volume level, hit the mute and the volume will change, then I want to hit the mute again and go back to the original volume.
How can I do that in a script?
This is what I have so far:
How can I get the current volume, save it and go back on the second press of the mute button?
Sub MuteTog (ByVal Parms() As String) Dim theDevice As Double Dim curVol As Double theDevice = parms(0) curVol = hs.DeviceValueEx(theDevice) if curVol > 0 then Dim cc as HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(theDevice, True, "(value)", False, False) cc.ControlValue = 0 Dim cr as HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) End if End Sub
