runScriptFunc - not returing anything?
    I am running the following code (Ubuntu):
      Dim test As String
      test = hs.RunScriptFunc("funksjoner.vb","Test","",FALSE,FALSE)
      hs.WriteLog ("Info", test)
    End Sub
    my funksjoner.vb file looks like this:
    Public Function Test(parms As Object) As Object
      Test = "Hey there"
    End Function
    But I do not get anything back, from the logfile:
    Sep-02 9:33:00 PM Info
    Sep-02 9:32:59 PM Event Running script in background: /usr/local/HomeSeer/scripts/test.vb
    Any suggestions on what I'm doing wrong?
    Regards
    Tom
    change
    Test = "Hey there" to Return "Hey there"
    tenholde
      Originally posted by tenholde View Post
      change
      Thanks, but unfortunately, still not working. Nothing is returned from the function.
        Try changing your writelog statement to:
        hs.WriteLog ("Info", test.ToString())
        You could also just change your function declare to
        Public Function Test(parms As Object) As String
          That throws an exception:
          Exception has been thrown by the target of an invocation.Object reference not set to an instance of an object
          Did not help, still result is blank...
            You need to set the 4th parameter for the RunscriptFunc to TRUE, otherwise it will not wait for a response from your function i.e.
            test = hs.RunScriptFunc("funksjoner.vb","Test","",TRUE,FALSE)
            Jon
              Yes, that solved it.
              Thank you so much!
