Question about device channel (retrieve possible control options)
    Lets say I have a virtual device like the one below with the possible statuses as below.
    Can I retrieve the possible values it can have?
    In the case below: 0, 10, 20 and 30
    I want to be able to cycle thru the options. From 0 to 30 in this case. But for another vd it could be 0 10 20 30 40 50 60 ...
    So I want to build me a script that is a bit universal for this application (lighting).
    All help is as always greatly appreciated.
    Click image for larger version  Name:	crap.png Views:	0 Size:	22.3 KB ID:	1334163Click image for larger version  Name:	crap.png Views:	0 Size:	138.5 KB ID:	1334164 ghgggg Click image for larger version  Name:	crap.png Views:	0 Size:	22.3 KB ID:	1334162
    I've used something like this:
                    Dim ValueStatusPairListing As HomeSeerAPI.VSVGPairs.VSPair() = hs.DeviceVSP_GetAllStatus(HSDev)
                    Dim ValueStatusPairs As HomeSeerAPI.VSPair
                    For Each ValueStatusPairs In ValueStatusPairListing
                        If ValueStatusPairs.PairType = 1 Then hs.writelog("VS Pairs",Cstr(ValueStatusPairs.Value))
                    Next
    Change HSDev in the first line to the reference ID of the device. This retrieves simple Status/Values (ValueStatusPairs.PairType = 1) like in your example. If there are other types that include ranges, then those would be ValueStatusPairs.PairType = 2 and need a bit more work to retrieve the range.
      Next
      Super thx again man!!! That saves me a lot of digging.
