Can Scripts Using the Same Variable Names Run Simultaneously?
    The title is pretty self explanatory, but I have created 3 countdown timers for my attic fans using scripts. The scripts are identical except for the device names, and timers. The script works fine when I run one at a time, but when all three attic fans are running, only the one started first works. The scripts use various variable names like TimeRemaining, HoursStr, etc., which are the same in all 3 scripts. I assume that the scripts are not self-contained, and therefore need to use different variable names?
    How and where in the scripts are you declaring your variables?
      Thanks for the reply sparkman . Here's the first part of the script with the variable declarations.
      Public Sub Main(param As Object)
          Dim Countdown_Status_Ref as integer = 1032     ' Device Number of Status Trigger
          Dim Countdown_Seconds_Ref as integer = 1036    ' Device Number of Counter
          Dim Timer as string = "Attic Fan Office"         ' Name of Timer to use
          Dim Run_Time_Ref as integer = 170              ' Name of Run Time Device to use
          Dim Time_Remaining_Ref as integer = 1033        ' Name of Time Remaining Virtual Dev
          Dim FlagOFF as integer = 0                      ' Flag Disabled or OFF
          Dim FlagON as integer = 100                     ' Flag Enabled or ON
          Dim Hours as integer = 0
          Dim HoursStr as String = ""
          Dim Minutes as integer = 0
          Dim MinutesStr as String = ""
          Dim TimeStr as String = ""
          Dim StartValue as integer = hs.DeviceValue(Run_Time_Ref)   ' Get initial start value
          Dim SecondsRemaining as integer = StartValue
        All of those variables you declare are local to that Main procedure. A separate running of this script will create its own copy of those variables. So from what is shown, that is not the problem.
        Check to see how your scripts are being started. Do you have the "Run only one copy at a time" set?
          Try changing “Public Sub Main” to just “Sub Main”. I never use the Public declaration in my scripts and have never experienced this issue (and I run a lot of scripts that use the same variable names).
            Another thing to do (assuming the previous suggestions do not fix the problem) is to examine the system log when the other scripts should be running. The log may tell you why.
              I checked that. No unusual log entries or errors.
                Thanks, that fixed it. All three are running at the same time with no issues.
