Object reference not set to an instance of an object with hs.GETUrl VB Script
    #16
    Dec-31 16:16:58 Z-Wave Device: Node 48 Z-Wave Battery Set to 70
    Dec-31 16:16:51 BLLAN Info Computer - Mobile juliet --- 1 PING failure
    Dec-31 16:16:50 Warning Not running script since its already running: C:/Program Files (x86)/HomeSeer HS3/scripts/getnews.vb Single instance option enabled in event properties
    Dec-31 16:16:50 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/getnews.vb
    Dec-31 16:16:50 Event Event Trigger "Alarm play around"
    Dec-31 16:16:50 Event Event Alarm play around triggered by the event page 'Run' button.
    Dec-31 16:16:45 Z-Wave Device: Node 48 Z-Wave Temperature Kegerator Set to 40.82 (F)
    Dec-31 16:16:45 Z-Wave Device: Node 48 Z-Wave Battery Set to 100
    Dec-31 16:16:36 BLLAN Info Computer - Mobile juliet is connected (Downtime: 1 mins, 26 secs)
    Dec-31 16:16:01 Z-Wave Device: Node 4 Z-Wave Main Energy Panel kW Hours 2 Set to 2206.207 (2206.207 kW Hours)
    Dec-31 16:16:01 Z-Wave Device: Node 4 Z-Wave kW Hours 1 Set to 2508.082 (2508.082 kW Hours)
    Dec-31 16:16:00 weatherXML Triggers to check: 0
    Dec-31 16:15:20 Z-Wave Device: First Hallway Basement Door Light Set to ON
    Dec-31 16:15:13 Log Info The log database is currently 44.61MB in size.
    Dec-31 16:15:09 BLLAN Info Computer - Mobile juliet is not connected (Uptime: 46 secs)
    Dec-31 16:15:09 BLLAN Info Computer - Mobile juliet --- 3 PING failures
    Dec-31 16:15:00 Log Maintenance 9577 records, selected by date/time, were removed from the log database.
    Dec-31 16:14:54 BLLAN Info Computer - Mobile juliet --- 2 PING failures
    Dec-31 16:14:38 BLLAN Info Computer - Mobile juliet --- 1 PING failure
    Dec-31 16:14:23 BLLAN Info Computer - Mobile juliet is connected (Downtime: 2 mins, 46 secs)
    Dec-31 16:14:01 Z-Wave Device: Node 4 Z-Wave Main Energy Panel kW Hours 2 Set to 2206.153 (2206.153 kW Hours)
    Dec-31 16:14:01 Z-Wave Device: Node 4 Z-Wave kW Hours 1 Set to 2508.03 (2508.03 kW Hours)
    Dec-31 16:12:42 Z-Wave Device: Node 48 Z-Wave Battery Set to 70
    Dec-31 16:12:31 Z-Wave Device: Node 48 Z-Wave Temperature Kegerator Set to 40.46 (F)
    Dec-31 16:12:31 Z-Wave Device: Node 48 Z-Wave Battery Set to 100
    Dec-31 16:12:01 Z-Wave Device: Node 4 Z-Wave Main Energy Panel kW Hours 2 Set to 2206.113 (2206.113 kW Hours)
    Dec-31 16:12:01 Z-Wave Device: Node 4 Z-Wave kW Hours 1 Set to 2507.988 (2507.988 kW Hours)
    Dec-31 16:11:37 BLLAN Info Computer - Mobile juliet is not connected (Uptime: 45 secs)
    Dec-31 16:11:37 BLLAN Info Computer - Mobile juliet --- 3 PING failures
    Dec-31 16:11:21 BLLAN Info Computer - Mobile juliet --- 2 PING failures
    Dec-31 16:11:06 BLLAN Info Computer - Mobile juliet --- 1 PING failure
    Dec-31 16:11:00 weatherXML Triggers to check: 0
    Dec-31 16:10:51 BLLAN Info Computer - Mobile juliet is connected (Downtime: 15 secs)
    Dec-31 16:10:36 BLLAN Info Computer - Mobile juliet is not connected (Uptime: 2 mins, 23 secs)
    Dec-31 16:10:36 BLLAN Info Computer - Mobile juliet --- 3 PING failures
    Dec-31 16:10:21 BLLAN Info Computer - Mobile juliet --- 2 PING failures
    Dec-31 16:10:14 Z-Wave Device: Node 47 Z-Wave Access Control Notification Set to NOTIFICATION for type Access Control Notification, Event: Lock Jammed
      #17
      I would consider rebooting the machine to have a fresh start as well. Also is your internet port 80?
        #18
        Originally posted by wkrasner View Post
        I appreciate you sticking with me. I copied preciley your syntax and settings and now I get
        One of the previous errors has the scripting engine locked up. Restart HS3.
          #19
            #20
            Is it working?
              #21
              Nope int 80 ext different
                #22
                The port number is immaterial.
                Does the HS3 server have internet access?
                Change the script as shown to add error trapping which may shed light on the problem
                Sub Main(parm as object)
                    Dim logName As String = "test"
                    Dim host As String = "http://lite.cnn.io"
                    Dim page As String = "/en"
                    Dim strip_tags As Boolean = False
                    Dim port As Integer = 80
                    Try
                        Dim resp As String = hs.GetURL(host, page, strip_tags, port)
                        hs.WriteLog(logName, resp)
                    Catch ex As Exception
                        'Error trapping
                        hs.WriteLogEx(logName, ex.ToString, "#ff0000")
                    End Try
                End Sub
                Edit: note the setting of 'strip_tags' false vs. true make a significant difference in the output.
                  #23
                  Can you go to the website in a browser and did you reboot? It may even require you to remove the rj45 plug if you are hardwired.
                  Here is my script in text form - I don't see anything different
                  Sub Main(parm As Object)
                  Dim Strdata As String
                  Strdata = hs.GetURL("http://lite.cnn.io", "/en" , true, 80)
                  hs.writelog ("test", Strdata)
                  End Sub
                    #24
                    Thank you all the cold reboot did the trick. Happy New Year
