Counter Script example
  • aa6vh
    Originally posted by jon00 View Post
    You must be doing something wrong. Takes about a second to increment from 0 to 10000
    Script below:
    Imports System.Diagnostics
    Sub Main(ByVal Parms As Object)
    Dim sw as new stopwatch
    sw.start()
    Dim CV As Integer = 10000
    hs.CounterReset("MyCounter") ' Set to 0
    While hs.CounterValue("MyCounter") <> CV
    hs.CounterIncrement("MyCounter")
    End While
    hs.writelog("Time", sw.ElapsedMilliseconds)
    End Sub
    (Windows system)
    It doesn't (from above). Looked at your code again: Realize that you only exit the loop when the counter reaches 10000. So that loop may have actually run 50000 times before reaching 10000 (due to the missed increments).
  • aa6vh
    I just ran this code, and the FDCount counter had a value of 28 when finished.
      For I As Integer = 1 to 100
        hs.CounterIncrement("FDCount")
      Next I
    Edited to add: I wonder if the "While hs.CounterValue("MyCounter") <> CV" allowed enough time for the counter to actually increment?
    Whatever, since it fails for me, I consider it unreliable.
  • jon00
    Originally posted by aa6vh View Post
    When I tried that, I found that the script was to fast for the increment. Some of the increments were missed. In other words, after doing the increment 10 times, the counter would be at a value less than 10 (like 6, for example). If I put in a short wait statement, it worked (but who wants to wait 10 seconds, 1 second per increment, just to get the counter to increment properly). Which is why when I need to set a counter to a specific value (like for a count down count), I use a virtual switch or a global variable instead. If I do not need to do that, I do use counters.
    (Note that this was on a Windows machine. A Raspberry Pi might behave differently.)
    Script below:
            sw.start()
            End While
        End Sub
    (Windows system)
  • AllHailJ
    I am running Ubuntu linux server on supermicro 1u 1/2 depth box with the latest stable mono. I do not see the issue you describe. Odd???
  • aa6vh
    Originally posted by AllHailJ View Post
    You set the counter to the value you need by incrementing in a do loop. Brute force and stupidity method.
  • AllHailJ
    I use this to scroll through weather animations I download on a daily and hourly basis. This accesses counters to display where I am in the loop (if move up to 20th go to 0 and if going below 0 set to 20). You set the counter to the value you need by incrementing in a do loop. Brute force and stupidity method. I use HTML file to tag to the current image file which reduces the size of moving files around. I also display this in HSTouch in a text box with the Temperature.html file being the file to display. Hope this helps.
    '12/23/2019 ScrollAnimation.vb
    'Script to scroll through static pictures and write html file to unique filename.
    IMPORTS System.IO
    IMPORTS System.Net
    IMPORTS System.Threading
    Sub Main(ByVal Parm As String) 'There are 0 parameters
    Dim sPath, sDisplayFile, Counter, Source, Destination As String
    Dim sFile(19) As String
    Dim dCounter As Double
    Dim iCnt, iMax, iIncCnt As Integer
    iMax = 19 'Set the maximum number of maps
    Counter = "TemperatureCntr" 'Created Counter
    'set the files and pathname for maps
    sPath = "/opt/HomeSeer/html/" 'The Path Name to the files
    sFile(0) = "Chart486.html"
    sFile(1) = "Chart492.html"
    sFile(2) = "Chart497.html"
    sFile(3) = "Chart688.html"
    sFile(4) = "Chart690.html"
    sFile(5) = "Chart691.html"
    sFile(6) = "Chart695.html"
    sFile(7) = "Chart706.html"
    sFile(8) = "Chart3285.html"
    sFile(9) = "Chart3374.html"
    sFile(10)= "Chart3409.html"
    sFile(11)= "Chart3497.html"
    sFile(12)= "Chart3618.html"
    sFile(13)= "Chart3679.html"
    sFile(14)= "Chart3683.html"
    sFile(15)= "Chart3687.html"
    sFile(16)= "Chart3691.html"
    sFile(17)= "Chart3736.html"
    sFile(18)= "Chart3787.html"
    sFile(19)= "Chart3837.html"
    sDisplayFile= "Temperature.html"
    dCounter = hs.CounterValue(Counter) 'Get the Map Counter Value
    iCnt = CInt(dCounter) ' Set the double to an integer
    'Make the list a loop and set the Counter correctly
    If iCnt < 0 Then 'Went through the floor value so set to ceiling value.
    hs.CounterReset(Counter)
    For iIncCnt = 1 To iMax+1
    hs.CounterIncrement(Counter)
    Next
    iCnt = iMax
    End If
    If iCnt > iMax Then 'Went through the ceiling value so set to the floor value
    iCnt = 0
    End If
    Source = sPath & sFile(iCnt)
    Destination = sPath & sDisplayFile
    'Overwrite or create the file that will be displayed.
    System.IO.File.Copy(Source, Destination, True)
    End Sub
  • aa6vh
    The above is correct. But one major deficiency with using counters within scripts is that there is no way to set a counter to a specific value (i.e set it to "10").
    I have set up virtual switches to act as counters for that reason, along with a few other advantages virtual switches give you.
  • will40
    I increment a counter in my scripts for example hs.CounterIncrement "Kitchen Light Off"
    These should work for you
    hs.CounterDecrement(CounterName As string)
    hs.CounterIncrement(CounterName As string)
    hs.CounterReset(CounterName As string)
    hs.CounterValue(CounterName As string)
  • MattL0
    I think the op wants to access counters via scripts
  • usLEDsupply
Name:	HS3 Counter Set.JPG
ID:	1369800Click image for larger version
  • djbeam
    started a topic Counter Script example
    Does anyone have a sample of a script that accesses and uses counters .. I have tried various ways and all I get is error messages .. I can see that the counter is defined within HS3 but I do not seem to be able to increment or display in a log message....
    Thanks for any help that can be given.
