Looking for a way to script a Z-Wave All Off
    If anyone has a script that emulates this, would you mind sharing it?
    Don
    You can do this with Easy Trigger
      I just created an event that does the All Off (using the ZWave action all off). Then I can invoke the event either from another event, or in script.
        Thanks. I am trying to avoid having an event calling a script calling an event. I have EasyTrigger, I'll try to play with that.
        Again, appreciate the suggestions.
        Don
          This is a good way to do it using an EasyTrigger group set to expression. The off command is only sent if the device isn't already off.
Name:	Annotation 2020-04-04 175803.jpg
          -Wade
            You can just user a normal event to do an all off. No need for any add-ons, scripts, or otherwise. Have the event trigger a z-wave action and set it to all off. As long as the device is set to respond to an all off command you are done.
            Karl S
            HS4Pro on Windows 10
            1070 Devices
            56 Z-Wave Nodes
            104 Events
            HSTouch Clients: 3 Android, 1 iOS
            Google Home: 3 Mini units, 1 Pair Audios, 2 Displays
              Unfortunately all on/off is depreciated in current zwave products. That and it felt like throwing a grenade into the zwave network due to the huge spike in network traffic as every device repeated the command. Devices didn't report their status after using all on/off so your device list was almost guaranteed to be out of sync, and there was significant network lag immediately after using for 1 to 2 minutes as I recall.
              I used to have 2 events that had all my lights in it to either turn all the lights on or off. I use the all off nightly. I got tired of updating the event as I expanded/updated my switches/dimmers, that and I felt it was inefficient to send an off command to a light that was already off. I started creating a script to mimic the functionality of all/on off. I was working on the script when a light bulb went off and I decided to just use easytrigger. Granted I still have to keep my easytrigger light group up to date, but it's a bit easier to add new devices since it excludes already selected devices from the device list.
              So there are 3 possible solutions. I'm pretty sure I saw someone mention an all on/off script and/or posted it.
              Number of Devices: 1005
              Number of Events: 293
                If I were going the script route I would do one script where I could pass the floor or some other grouping and then create an event for each group. A quick skim of this thread had some code. There is some code here to start with.
                Karl S
                1070 Devices
                56 Z-Wave Nodes
                104 Events
                  Many thanks for the script references.
                  Don
