Problem with immediate script &hs.setdevicevaluebyref(217,0,False)
    Tried using this command for the first time on this system and it barfs...
    Log error:
    Running script /tmp/K1.vb :Object reference not set to an instance of an object->Does entry point &hs.setdevicevaluebyref(217,0,False) exist in script? at Scheduler.clsRunVBNetScript.ExecuteScript () [0x0039b] in :0
    My system Info:
    Date/time=2020-06-03 6:12:55 PM PDT
    Version=HS4 Pro Edition 4.0.6.0 (Linux - Debian "Buster")
    License=Registered
    Uptime=0 Days 1 Hour 6 Minutes 48 Seconds
    Lan IP=192.168.1.103 (Debian10)
    Device Count=152
    Event Count=53
    Plugins Enabled=Pushover 3P:,SDJ-Health:,Z-Wave:,Insteon:,drhsEventEnabler:,JowiHue:
    Modules/Threads=100 Modules, 72 Threads
    Available Threads=399
    HomeSeer Memory Used=174 Mbytes
    Plugins Installed=Current Cost 3P 0.0.0.42,drhsEventEnabler 1.0.0.0,Insteon 3.0.7.8,JowiHue 4.0.0.20,mcsMQTT 5.2.4.9,NetCAM 3.0.0.14,Pushover 3P 0.0.0.48,SDJ-Health 3.0.8.5,Z-Wave 3.0.2.0
    Mono version:
    root@Debian10:/usr/local/HomeSeer# mono --version
    Mono JIT compiler version 6.8.0.123 (tarball Tue May 12 15:15:28 UTC 2020)
    TLS: __thread
    SIGSEGV: altstack
    Notifications: epoll
    Architecture: amd64
    Disabled: none
    Misc: softdebug
    Interpreter: yes
    LLVM: yes(610)
    Suspend: hybrid
    GC: sgen (concurrent by default)
    On possibly a related note...
    Today I found and tried Manage_Voice_Enabled_Devices.aspx
    I am not sure what I've broken!
    HS4Pro running on HP ProDesk
    Plugins: Z-Wave, mcsMQTT, SDJ-Health, CurrentCost
    HA 0.114.3 running on ThinkCenter M73
    Integrations: AccuWeather, Alexa, Geofency, IPP, Life360, Logitech Harmony Hub, Insteon, Mobile App, MQTT, OpenZWave, SpeedTest, Ubiquiti UniFi, UPnP
    OpenZWave 1.6 running on RPi3B+ with RaZberry controller
    try to run this on your pc via ssh :
    sudo touch /usr/bin/vbnc
    sudo chmod +x /usr/bin/vbnc
    sudo cat /usr/bin/vbnc  > /usr/bin/vbc
    sudo apt install libmono-cecil-vb0.9-cil libmono-microsoft-visualbasic10.0-cil
      Put &nhs. at the beginning instead of &hs.
        Tried that already earlier but here it is again...
        2020-06-03 8:05:52 PM HomeSeer Event Running script statement immediately: &nhs.setdevicevaluebyref(217, 0, False)("&hs.setdevicevaluebyref(217,0,False)")
        2020-06-03 8:05:53 PM HomeSeer Error 3 Running script /tmp/K4.vb :Object reference not set to an instance of an object->Does entry point &hs.setdevicevaluebyref(217,0,False) exist in script? at Scheduler.clsRunVBNetScript.ExecuteScript () [0x0039b] in :0
        root@Debian10:/usr/local/HomeSeer# cat /tmp/K4.vb
        Function Main(parm as object)
        dim result as object
        result=hs.setdevicevaluebyref(217, 0, False)("&hs.setdevicevaluebyref(217,0,False)")
        return(result)
        End Function
          sudo cat /usr/bin/vbc /usr/bin/vbnc
          sudo apt intall libmono-cecil-vb0.9-cil libmono-microsoft-visualbasic10.0-cil
          Trying now...stay tuned!
            I already have vbnc
            root@Debian10:/usr/bin# ls -al vb*
            -rwxr-xr-x 1 root root 103 May 12 07:53 vbc
            -rwxr-xr-x 1 root root 103 May 12 07:53 vbc.new
            -rw-r--r-- 1 root root 158 Jun 3 15:20 vbc.old
            -rwxr-xr-x 1 root root 83 Apr 17 06:58 vbnc
            -rwxr-xr-x 1 root root 115 Apr 17 06:58 vbnc2
            ...already has u+x
            root@Debian10:/usr/bin# cat vbc
            #!/bin/sh
            exec /usr/bin/mono --gc-params=nursery-size=64m $MONO_OPTIONS /usr/lib/mono/4.5/vbc.exe "$@"
            #!/bin/sh
            exec /usr/bin/mono --debug $MONO_OPTIONS /usr/lib/mono/4.5/vbnc.exe "$@"
            I had manipulated those before...
            root@Debian10:/usr/bin# cat vbc.old
            #!/bin/bash
            for x; do
            if [[ $x = '/tmp'* ]]; then
            sed -i '1{/#Externa/d}' $x
            fi
            done
            root@Debian10:/usr/bin# sudo apt intall libmono-cecil-vb0.9-cil libmono-microsoft-visualbasic10.0-cil
            E: Invalid operation intall
            root@Debian10:/usr/bin# apt install libmono-cecil-vb0.9-cil libmono-microsoft-visualbasic10.0-cil
            Reading package lists... Done
            Building dependency tree
            Reading state information... Done
            libmono-cecil-vb0.9-cil is already the newest version (4.7-0xamarin3+debian10b1).
            libmono-cecil-vb0.9-cil set to manually installed.
            libmono-microsoft-visualbasic10.0-cil is already the newest version (4.7-0xamarin3+debian10b1).
            libmono-microsoft-visualbasic10.0-cil set to manually installed.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Originally posted by dbrunt View Post
              I already have vbnc
              ...already has u+x
              #!/bin/sh
              #!/bin/sh
              #!/bin/bash
              for x; do
              fi
              done
              sorry i missed a > in the third command . on post #2. Please retry them .
              edit : I did messed up the sequence between vbnc and vnc . please try again
                Looks like you replaced vbc with vbnc .. that's the wrong direction - vbc should replace vbnc.
                https://forums.homeseer.com/forum/de...bnc-deprecated
                 more /usr/bin/vbnc
                #!/bin/sh
                   more /usr/bin/vbnc
                  #!/bin/sh
                  Thanks ! corrected the post #2
                    return(result)
                    End Function
                    Looking at the output, it seems like the temp .vb file that HS creates is messed up. Can you look at that file and confirm what is inside it? It’s /tmp/K4.vb according to the logs but if you run it again, it may be in a new file.
                      So I replaced vbnc with vbc:
                      # cat vbnc
                      #!/bin/sh
                      Restarted HS4 and re-ran my event. Same error:
                      # cat /tmp/K1.vb
                      return(result)
                        [off topic]... BTW, if you see this in my sig, how do I change it???
                        HS2 v2.5.0.81, Z-Troller Serial v1.17, Insteon 1.7.3.1, AC-RF2 v1.1.3226.27426, BLRadar v1.0.101.0, CurrentCost 1.0.0.57
                        It's gotta be like 15+ years old!
                          As sparkman indicated, there may be an issue with how the immediate script is being encapsulated into the temporary script. But try the ASPX and see if that works.
                            Do not see any signature here.
                              Signature edit - click on your user name in the upper right, select My Profile, then Edit Settings. Go to Account tab, about half way down is 'Edit Post Signature'.
                              I have 'Show signatures' unchecked so don't see those.
                              Edit: it's possible that they changed it so you have to have some number of posts before the signature can be set. So get busy!
