Originally posted by zwolfpack
View Post
Problem with immediate script &hs.setdevicevaluebyref(217,0,False)
Guest
Yay! Thanks!!!!!
This morning I thought of another way to manage them.
Create & assign an HS4 Category, then filter before using Bulk Edit...HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
Originally posted by jon00 View PostYou need 500 posts before you get access to your signature settings.HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
We now return you to our regularly scheduled programming...
Running script /tmp/K1.vb :Object reference not set to an instance of an object->Does entry point &hs.setdevicevaluebyref(217,0,False) exist in script? at Scheduler.clsRunVBNetScript.ExecuteScript () [0x0039b] in :0
2020-06-06 6:07:50 PM
HomeSeer
Event
Running script statement immediately: &nhs.setdevicevaluebyref(217, 0, False)("&hs.setdevicevaluebyref(217,0,False)")
HomeSeer
Event
Event Trigger "Status Updates Bedroom Blind Multilevel Sub"
Date/time=2020-06-06 6:10:37 PM PDT
Version=HS4 Pro Edition 4.0.7.0 (Linux)
License=Registered
Uptime=0 Days 0 Hours 9 Minutes 44 Seconds
Lan IP=192.168.1.103 (Debian10)
Device Count=148
Event Count=53
Plugins Enabled=Pushover 3P:,SDJ-Health:,Z-Wave:,Insteon:,drhsEventEnabler:,Zigbee:
Modules/Threads=83 Modules, 65 Threads
Available Threads=399
HomeSeer Memory Used=175 Mbytes
Plugins Installed=Current Cost 3P 0.0.0.42,drhsEventEnabler 1.0.0.0,Insteon 3.0.7.8,JowiHue 4.0.0.20,mcsMQTT 5.2.4.9,NetCAM 3.0.0.14,Pushover 3P 0.0.0.48,SDJ-Health 3.0.8.5,Zigbee 4.0.6.0,Z-Wave 3.0.2.0HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
On my test HS3-Pi, I create a couple of similar events with immediate commands
&hs.setdevicevaluebyref(456, 0, False)
and
&hs.setdevicevaluebyref(456, 100, False)
The generated files /tmp/K2.vb look like this
Function Main(parm as object)
dim result as object
result=hs.setdevicevaluebyref(456, 100, False)
return(result)
End Function
If you create a brand new event, is there any difference?
Success!
2020-06-06 9:04:21 PM
HomeSeer
Event
Event Test New Event triggered by the event page 'Run' button.
HomeSeer
Event
Event Trigger "Test New Event"
HomeSeer
Event
Running script statement immediately: &hs.SetDeviceValueByRef(217,0,False)
...no error and device was changed. I also tried &nhs and it worked also.HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
- Likes 1
