Debugging script errors
    Hey,
    So I have been trying to install and run a traccar (gps tracking server) script for integration into HS.
    I've had many issues so far, some just plain silly and others frustrating as hell.
    I am now on the final stretch I think, just a few niggles.
    I am getting the following errors when trying to run the script.
    Jun-13 00:36:58 Error 1 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb :Exception has been thrown by the target of an invocation.Object reference not set to an instance of an object.
    Jun-13 00:36:58 Traccar Error Connecting to Database traccar: Incorrect TIMESTAMP value: 'NULL'
    Is there a way to increase verbose output do you know?
    I've tried running the script with tenscripts, but other than build errors it does still compile and run but I don't really know how to debug from there.
    Any ideas?
    Traccar.vb
    ' Script created by Rutger Bockholts and is provided on https://rutg3r.com for free.
    ' Version 4.6.01 // November 15 2019
    ' Script is tested with Traccar 4.6
    ' The script will run in 4 stages:
    ' 1: Get columns and values data from Traccar table 'positions' and store both in seperate arrays, except the last column "Attributes"
    ' 2: Get the last column "Attributes" and add all the Keys and Values of the KVPair to seperate arrays
    ' 3: Add additional virtual devices to the arrays, to provide seperate data
    ' 4: Get data from all arays and store them in the virtual devices
    ' 5: Will create a recurring event, that runs once a day, to run the "DailyDistance" script. The event has the status enabled
    Imports MySql.Data.MySqlClient
    Imports Newtonsoft.Json
    Imports Newtonsoft.Json.Linq
    Imports System.Net
    Sub Main(ByVal Cpt as Object)
    ' ********** START USER CHANGE **********
    Dim Debug as Boolean = true ' true/false
    Dim UseMetrics as Boolean = false ' true=Kilometers // false=Miles
    Dim UseGoogleStreetview as Boolean = false ' true/false / API code necessary
    Dim GoogleStreetview_API = "xxx"
    Dim DBserver = "localhost"
    Dim DBuser = "admin"
    Dim DBpassword = "password"
    Dim DBtraccar = "traccar"
    ' Coordinates Home
    Dim lat_home = 54.271866 ' Input with decimal point
    Dim lon_home = -0.938364 ' Input with decimal point
    ' Coordinates Work
    Dim lat_work = 54.271866 ' Input with decimal point
    Dim lon_work = 0.938364 ' Input with decimal point
    ' Aerial distance from above locations
    Dim GeofenceHome = 0.1 ' Example: PresenceHome will be TRUE(ON) when car location is within '0.1' kilometers/miles of Home location.
    Dim GeofenceWork = 0.1 ' Example: PresenceWork will be TRUE(ON) when car location is within '0.2' kilometers/miles of Work location.
    ' ********** END USER CHANGE **********
    Dim HS_Port as String = hs.GetINISetting("Settings", "gWebSvrPort", "") ' Homeseer web port
    Dim HS_IPAddress as String = hs.GetIPAddress ' Homeseer ip address
    ' Dim HS_Version as String = hs.GetINISetting("Settings", "gLastRunVersion", "") ' Homeseer version
    ' Dim streetview_store_path as String = hs.GetAppPath & "\html\Streetview\" ' Local HS file location for saving Streetview picture(s)
    Dim streetview_store_path as String = "C:\Program Files (x86)\HomeSeer HS3\html\Streetview\" ' Local HS file location for saving Streetview picture(s)
    ' If Dir(streetview_store_path) = "" Then
    ' MkDir (streetview_store_path)
    ' If Debug = true Then hs.writelog("Folder", "Storage folder created: " & streetview_store_path)
    ' Else
    ' If Debug = true Then hs.writelog("Folder", "Storage folder already exists")
    ' End If
    Dim streetview_open_path as String = "http://" & HS_IPAddress & ":" & HS_Port & "/Streetview/" ' Web location (in html folder) for saving Streetview picture(s)
    ' Dim streetview_open_path as String = "http://192.168.1.123:81/Streetview/" ' Web location (in html folder) for saving Streetview picture(s)
    Dim conn as MySqlConnection
    Dim conn1 as MySqlConnection
    Dim myCommand as New MySqlCommand
    Dim myCommand1 as New MySqlCommand
    ' Variables for creating devices
    Dim DevExists
    Dim BaseRef as Integer = 0
    Dim dv as Scheduler.Classes.DeviceClass = Nothing
    Dim root_dv as Scheduler.Classes.DeviceClass = Nothing
    Dim DVaddress as String ' Devicename prefix (including space!!)
    Dim DevicesArrayD as New ArrayList ' Create array for all GPS Devices
    Dim DevicesArrayN as New ArrayList ' Create array for all GPS Device names
    Dim DevicesArrayK as New ArrayList ' Create array for all Keys
    Dim DevicesArrayV as New ArrayList ' Create array for all Values
    Dim DevicesArrayE as New ArrayList ' Create array for all Values Extensions (extension of value string, like 'miles' )
    ' Event "Traccar_DailyDistance"
    Const ScriptName = "Event-create"
    Dim strEventGroup as String = "GPS"
    Dim strEventName as String = "Traccar_DailyDistance"
    Dim strEventLaunchByRefProc as String = "LaunchEventByRef"
    Dim strEventLaunchScript as String = "Traccar_DailyDistance.vb"
    Dim strEventLaunchByNameProc as String = "" ' Not in use
    Dim strEventLaunchProcParams as String = "" ' Not in use
    Dim batterymonitor_old_data as Double
    Dim ButtonInfo() As String
    Dim units
    Dim R ' Radius for calculating AERIAL distance
    If UseMetrics = true
    units = " km" ' String extension for distance devices
    R = 6372.8 ' Earth radius in kilometers
    Else
    units = " mi" ' String extension for distance devices
    R = 3959.9 ' Earth radius in miles
    End If
    Dim Columnname as String
    Dim Columnvalue
    Dim gps_id
    Dim gps_name
    If Debug = true Then hs.writelog("Debug", Debug)
    If Debug = true Then hs.writelog("HS version", hs.version)
    If Debug = true Then hs.writelog("UseMetrics", "in " & units)
    If Debug = true Then hs.writelog("strtvw_open", streetview_open_path)
    If Debug = true Then hs.writelog("strtvw_store", streetview_store_path)
    Try
    ' Get GPS tracker id and names
    conn1 = New MySqlConnection()
    conn1.ConnectionString = "server=" & DBserver & "; user id=" & DBuser & "; password=" & DBpassword & "; database=" & DBtraccar & ""
    myCommand.CommandText = "SELECT id as id, name as name from tc_devices WHERE lastupdate != 'NULL'" ' When a new tracker is added but don't have uploaded data yet, the script will continue running
    myCommand.Connection = conn1
    conn1.Open()
    myCommand.ExecuteNonQuery()
    Dim myAdapterG as New MySqlDataAdapter
    myAdapterG.SelectCommand = myCommand
    Dim myDataG as MySqlDataReader
    myDataG = myCommand.ExecuteReader()
    If Debug = true Then hs.writelog("GPS_ids", myDataG.FieldCount) ' Show amount of id's/gps devices
    If Debug = true Then hs.writelog("GPS_cmd", myCommand.CommandText)
    ' Loop for every gps_id the whole script
    Dim g as Integer = 0
    If myDataG.HasRows Then
    While myDataG.Read
    gps_id= myDataG(g).ToString
    If Debug = true Then hs.writelog("GPS-Array:" & g, gps_id(g))
    ' Add extra devices to DevicesArrayK
    conn = New MySqlConnection()
    conn.ConnectionString = "server=" & DBserver & "; user id=" & DBuser & "; password=" & DBpassword & "; database=" & DBtraccar & ""
    myCommand.CommandText = "SELECT tc_devices.name as trackername, TIMESTAMPDIFF(SECOND,servertime, NOW()) as lastupdate, tc_positions.* FROM tc_positions JOIN tc_devices ON tc_devices.id = " & gps_id & " and tc_positions.deviceid = " & gps_id & " Order by id DESC LIMIT 1"
    If Debug = true Then hs.writelog("Columns", myCommand.CommandText)
    conn.Open()
    Dim myAdapter as New MySqlDataAdapter
    myAdapter.SelectCommand = myCommand
    Dim myData as MySqlDataReader
    myData = myCommand.ExecuteReader()
    Dim address_old_Ref
    Dim address_old_data
    Dim x as Integer = 0
    If myData.HasRows Then
    While myData.Read
    DVaddress = MyData("trackername")
    If Debug = true Then hs.writelog("Trackername", DVaddress)
    DevicesArrayK.Add("GPS Tracker")
    DevicesArrayV.Add("")
    DevicesArrayE.Add(DVaddress)
    ' Get column names and values
    For x = 0 To myData.FieldCount - 1
    Columnname = StrConv(myData.GetName(x), VbStrConv.ProperCase) ' Change first character to Uppercase)
    Columnvalue = myData(x).ToString
    ' If Address value is NULL, the current value from the HS device, will be kept.
    If Columnname = "Address" Then
    If (IsDbNull(Columnvalue) OR String.IsNullOrEmpty(Columnvalue) OR Columnvalue="NULL")
    If Debug = true Then hs.writelog("Address", "DB field is empty. Keep old value")
    address_old_Ref = hs.GetDeviceRefByName(DVaddress & "_Address")
    If Debug = true Then hs.writelog("addr_old_Ref", address_old_Ref)
    address_old_data = hs.DeviceString(address_old_Ref)
    If Debug = true Then hs.writelog("addr_old_data", address_old_data)
    Columnvalue = address_old_data
    If Debug = true Then hs.writelog("Keep old value", Columnvalue)
    End If
    Elseif Columnname = "Speed" Then
    ' Speed data from MySQL is in knots
    If UseMetrics = true Then
    Columnvalue = Math.Round(Columnvalue*1.85, 0) ' From knots to km/h, 0 decimals
    If Debug = true Then hs.writelog("Speed" , "New: " & Columnvalue)
    End If
    Elseif Columnname = "Attributes" Then ' Attributes objects will be created later
    Exit For
    Elseif Columnname = "Network" Then ' Network objects will be created later
    Exit For
    End If
    DevicesArrayK.Add(Columnname)
    DevicesArrayV.Add(Columnvalue)
    DevicesArrayE.Add("")
    If Debug = true Then hs.writelog("Array", DevicesArrayK(x) & ": " & DevicesArrayV(x) & " " & DevicesArrayE(x))
    Next
    'Add 'Attributes' devices to array
    Dim json as String ' This is the string of json data that needs decoding
    ' Dim obj as New Object
    json = myData("attributes") ' Grab all content from Attributes column field.
    'Possible result: {"event":35,"sat":"12","gsm":"25","hdop":"0.8","odometer":"2 9576128","runtime":"45513310","mcc":204,"mnc":8,"lac":3480," cid":52621,"status":"0000","adc1":21,"battery":726,"power":2 63,"ip":"111.222.333.444","distance":0.0,"'":9426362.17}
    ' Change json output to string
    If Debug = true Then hs.writelog("Attributes", json)
    Dim json1 = Replace(json, "[", "") ' Remove bracket
    Dim json2 = Replace(json1, "]", "") ' Remove bracket
    Dim json3 = Replace(json2, "{", "") ' Remove bracket
    Dim json4 = Replace(json3, "}", "") ' Remove bracket
    Dim json5 = Replace(json4, """", "") ' Remove double quotes, so plain text string is left over (aaa:123,zzz:654,etc)
    Dim counter as String() = json5.Split(",") ' Count amount of commas in String json5, so we know how many devices should be created.
    If Debug = true Then hs.writelog("Attr-Counter", counter.Length)
    Dim results() as String = json5.Split(",") ' create array of all results
    ' Attributes object expanding
    For i as Byte = 0 To counter.Length - 1
    Dim combined as String = results(i)
    If Debug = true Then hs.writelog("Counter: " & i, "Key & Value: " & combined)
    ' Add Key to new array (first part of results)
    Dim leftpart as String = combined.Split(":")(0)
    ' If Debug = true Then hs.writelog("leftpart", leftpart)
    leftpart = StrConv(leftpart, VbStrConv.ProperCase)
    DevicesArrayK.Add(leftpart)
    ' Add Value to new array (last part of result)
    Dim rightpart = combined.Split(":")(1)
    ' If Debug = true Then hs.writelog("rightpart", rightpart
    If leftpart = "Odometer" Then
    ' Odometer MySQL value is shown without decimal seperator, so it will be divided by 1000 and set to the correct units
    rightpart = Math.Round(rightpart/1000, 3) ' /1000 and calculate to kilometers, 3 decimals
    Else
    rightpart = rightpart/1609.344
    rightpart = Math.Round(rightpart, 3) ' /1000 and calculate to miles, 3 decimals
    End If
    DevicesArrayV.Add(rightpart)
    If Debug = true Then hs.writelog("Odometer" , "Odometer new: " & rightpart & units)
    Elseif leftpart = "Totaldistance" Then
    rightpart = CLng(rightpart)
    rightpart = rightpart/1.609344
    rightpart = Math.Round(rightpart,0) ' /1000 and calculate to miles
    Elseif leftpart = "Power" Then
    rightpart = Math.Round(rightpart*1, 2)
    Elseif leftpart = "Battery" Then
    ' In case a "Battery" device will be created, you want to monitor the battery level as well. The dropdown menu of this device can be set manually after device creation. An additonal virtual device will go in alert modu when the dropdown value is reached (from high to low).
    DevicesArrayK.Add("Battery Monitor") ' Will contains a dropdown menu where a trigger value can be chosen. This value will be used to set the "battery Level Alert" device to ON/Off.
    Dim batterymonitor_old_Ref = hs.GetDeviceRefByName(DVaddress & "_Battery Monitor")
    If Debug = true Then hs.writelog("battmon_ref", DVAddress & " - " & batterymonitor_old_Ref)
    batterymonitor_old_data = hs.DeviceValueEx(batterymonitor_old_Ref)
    If Debug = true Then hs.writelog("battmon_val", DVAddress & " - " & batterymonitor_old_data)
    batterymonitor_old_data = batterymonitor_old_data
    If (batterymonitor_old_data = 0)
    DevicesArrayV.Add("0")
    Else
    DevicesArrayV.Add(batterymonitor_old_data)
    End If
    DevicesArrayE.Add(" Volt")
    DevicesArrayK.Add("Battery Alert")
    Else
    End If
    Next
    Dim Accuracy = MyData("accuracy")
    If Debug = true Then hs.writelog("Accuracy", Accuracy)
    DevicesArrayK.Add("Accuracy")
    DevicesArrayV.Add(Accuracy)
    ' Network object expanding
    Dim jsonN as String ' This is the string of json data that needs decoding
    jsonN = myData("network") ' Grab all content from Network column field, which can be sometimes empty(=null)
    If (IsDbNull(jsonN) OR String.IsNullOrEmpty(jsonN) OR jsonN="null") Then
    If Debug = true Then hs.writelog("Network", "DB field is empty")
    Else
    'Possible result: {"radioType":"gsm","considerIp":false,"cellTowers":[{"cellId":14310,"locationAreaCode":3480,"mobileCountryCode": 204,"mobileNetworkCode":8,"signalStrength":16}]}
    If Debug = true Then hs.writelog("network", json)
    Dim jsonN1 = Replace(jsonN, "[", "") ' Remove bracket
    If Debug = true Then hs.writelog("jsonN1", jsonN1)
    Dim jsonN2 = Replace(jsonN1, "]", "") ' Remove bracket
    Dim jsonN3 = Replace(jsonN2, "{", "") ' Remove bracket
    Dim jsonN4 = Replace(jsonN3, "}", "") ' Remove bracket
    Dim jsonN5 = Replace(jsonN4, """", "") ' Remove double quotes, so plain text string is left over (aaa:123,zzz:654,etc)
    If Debug = true Then hs.writelog("jsonN5", jsonN5)
    If jsonN5.Contains("cellTowers") = True
    jsonN5 = Replace(jsonN5, "cellTowers:", "")
    If Debug = true Then hs.writelog("jsonN5-new", jsonN5)
    End If
    Dim counterN as String() = jsonN5.Split(",") ' Count amount of commas in String jsonN5, so we know how many devices should be created.
    If Debug = true Then hs.writelog("Attr-CounterN", counterN.Length)
    Dim resultsN() as String = jsonN5.Split(",") ' create array of all results
    For n as Byte = 0 To counterN.Length - 1
    Dim combinedN as String = resultsN(n)
    If Debug = true Then hs.writelog("Counter: " & n, "KeyN & ValueN: " & combinedN)
    Dim leftpartN as String = combinedN.Split(":")(0)
    leftpartN = StrConv(leftpartN, VbStrConv.ProperCase)
    DevicesArrayK.Add(leftpartN)
    Dim rightpartN = combinedN.Split(":")(1)
    DevicesArrayV.Add(rightpartN)
    Next
    End If
    End While
    End If
    conn.Close()
    conn.Dispose()
    ' Add additional device names to DevicesArray
    Dim latitude_dataKey as Integer = DevicesArrayK.IndexOf("Latitude", 1)
    Dim latitude_data = DevicesArrayV(latitude_dataKey)
    If Debug = true Then hs.writelog("Latitude", latitude_data)
    Dim longitude_dataKey as Integer = DevicesArrayK.IndexOf("Longitude", 1)
    Dim longitude_data = DevicesArrayV(longitude_dataKey)
    If Debug = true Then hs.writelog("Longitude", longitude_data)
    Dim course_dataKey as Integer = DevicesArrayK.IndexOf("Course", 1)
    Dim course_data = DevicesArrayV(course_dataKey)
    If Debug = true Then hs.writelog("Course", course_data)
    Dim lat_car = latitude_data
    Dim lon_car = longitude_data
    ' Start extra Motion checks
    Dim moving_data as Boolean = false
    ' Because at least in Traccar version 3.17 the "Motion" device is available, but the reported data is not always > 0, a check will be done on other devices to see if we can track motion
    ' When object Speed is available and > 0, then Motion is true.
    Dim speed_data
    Dim speed_dataKey as Integer = DevicesArrayK.IndexOf("Speed", 1)
    If speed_dataKey <> -1 ' Object exist
    If Debug = true Then hs.writelog("SpeedKey", speed_dataKey)
    speed_data = DevicesArrayV(speed_dataKey)
    If speed_data > 2 Then
    moving_data = true
    End If
    End If
    ' When object Status is available and > 0, then Motion is true.
    Dim status_data
    Dim status_dataKey as Integer = DevicesArrayK.IndexOf("Status", 1)
    If status_dataKey <> -1 ' Object exist
    If Debug = true Then hs.writelog("StatusKey", status_dataKey)
    status_data = DevicesArrayV(status_dataKey)
    If status_data > 0 Then
    moving_data = true
    End If
    End If
    ' When object Motion is available and True, then Motion is true.
    Dim motion_data
    Dim motion_dataKey = DevicesArrayK.IndexOf("Motion", 1)
    If motion_dataKey <> -1 ' Object exist
    If Debug = true Then hs.writelog("MotionKey", motion_dataKey)
    motion_data = DevicesArrayV(motion_dataKey) ' Result is a string
    If motion_data = "true" Then
    moving_data = true
    End If
    End If
    ' In the last case, the Totaldistance values from the current object and the previous one from Homeseer will be compared. When difference <> 0 then Motion is true.
    Dim totaldistance_new_data as Long ' Object value could be sometimes with an exponential (2.359254978E7), therefor calculation will give strange values
    Dim totaldistance_old_Ref = hs.GetDeviceRefByName(DVaddress & "_Totaldistance")
    Dim totaldistance_old_data = hs.Devicevalue(totaldistance_old_Ref) ' No decimal value taken here
    Dim totaldistance_diff
    Dim totaldistance_new_dataKey as Integer = DevicesArrayK.IndexOf("Totaldistance", 1)
    If totaldistance_new_dataKey <> -1 ' Object exist
    If Debug = true Then hs.writelog("TotaldistKey", totaldistance_new_dataKey)
    totaldistance_new_data = DevicesArrayV(totaldistance_new_dataKey)
    totaldistance_diff = totaldistance_new_data - totaldistance_old_data
    If totaldistance_diff > 1 Then
    moving_data = true
    End If
    End If
    If Debug = true Then hs.writelog("TD-old", totaldistance_old_data)
    If Debug = true Then hs.writelog("TD-new", totaldistance_new_data)
    If Debug = true Then hs.writelog("TD-diff", totaldistance_diff)
    ' Additional device to track motion data for several objects.
    Dim moving_string
    moving_string = speed_data & "|" & status_data & "|" & totaldistance_diff & "|" & motion_data & "|" & moving_data
    If Debug = true Then hs.writelog("moving_string", DVaddress & ": " & moving_string)
    DevicesArrayK.Add("Moving")
    DevicesArrayE.Add(moving_data)
    ' Object Lastupdate
    Dim lastupdate_data
    Dim lastupdate_dataKey = DevicesArrayK.IndexOf("Lastupdate", 1)
    If lastupdate_dataKey <> -1 ' Object exist
    If Debug = true Then hs.writelog("Lastupdate_Ref", DVAddress & ": "& lastupdate_dataKey)
    lastupdate_data = DevicesArrayV(lastupdate_dataKey)
    If Debug = true Then hs.writelog("Lastupdate_Data", DVAddress & ": "& lastupdate_data)
    End If
    ' End extra Motion checks
    DevicesArrayK.Add("Google Maps")
    Dim google_maps as String = "<iframe width='240' height='240' frameborder='0' scrolling='no' marginheight='0' marginwidth='0' src='http://maps.google.nl/maps?q=" & latitude_data & "," & longitude_data & "&ie=UTF8&z=14&t=m&output=embed'></iframe><br />Link to <a href='http://maps.google.com/maps?q=" & latitude_data & "," & longitude_data & "' target='_blank'>location</a>"
    DevicesArrayV.Add(google_maps)
    Dim Streetview_API_Ref = hs.GetDeviceRefByName(DVaddress & "_Streetview API")
    Dim Streetview_API_data = hs.DeviceValue(Streetview_API_Ref)
    ' If Debug = true Then hs.writelog("Google Maps", DVAddress & ": "& google_maps)
    If Debug = true Then hs.writelog("moving_data", "Moving override: " & moving_data)
    Dim streetview_web
    Dim streetview_open = streetview_open_path & "streetview_" & DVAddress & ".png"
    Dim streetview_store = streetview_store_path & "streetview_" & DVAddress & ".png"
    If Debug = true Then hs.writelog("UseStrtvw", UseGoogleStreetview)
    If UseGoogleStreetview = true
    ' For reducing the amount of API calls to Google, the Google url will be generated only when speed > 0, otherwise the saved image will be loaded which is generated at the entry when speed > 0.
    streetview_web = "https://maps.googleapis.com/maps/api/streetview?size=640x480&location=" & latitude_data & "," & longitude_data & "&heading=" & course_data & "&pitch=-0.76&key=" & GoogleStreetview_API
    Dim motion_Ref = hs.GetDeviceRefByName(DVaddress & "_Motion")
    Dim motion_data_timediff = DateDiff("s",hs.devicelastchangeref(motion_Ref),now) ' Calculate amount of seconds since last devicelastchange
    If Debug = true Then hs.writelog("Timediff", motion_data_timediff)
    If ((motion_data_timediff < 120 OR moving_data = "True" OR moving_data = True OR Streetview_API_data < 0) AND lastupdate_data < 600) Then ' Requesting API call continues 120 seconds after tracker has no motion anymore
    ' Save Streetview images to disk
    Dim fileReader as New WebClient()
    fileReader.DownloadFile(streetview_web, streetview_store)
    Streetview_API_data += 1 ' Increase API call counter
    If Debug = true Then hs.writelog("API value New", Streetview_API_data)
    End If
    Dim streetview_data = "<img width='300' height='240' frameborder='0' scrolling='no' marginheight='0' marginwidth='0' src='" & streetview_open & "'</img><br />Link to <a href='" & streetview_open & "' target='_blank'>Streetview</a>"
    DevicesArrayK.Add("Google Streetview")
    DevicesArrayV.Add(streetview_data)
    If Debug = true Then hs.writelog("strvw_web", streetview_web)
    If Debug = true Then hs.writelog("strvw_open", streetview_open)
    If Debug = true Then hs.writelog("strvw_store", streetview_store)
    DevicesArrayK.Add("Streetview API")
    DevicesArrayV.Add(Streetview_API_data)
    DevicesArrayE.Add(" API calls")
    End If
    hs.writelog("lat_tracker", lat_car)
    hs.writelog("lon_tracker", lon_car)
    hs.writelog("lat_home", lat_home)
    hs.writelog("lon_home", lon_home)
    hs.writelog("lat_work", lat_work)
    hs.writelog("lon_work", lon_work)
    End If
    DevicesArrayK.Add("Distance to Home")
    'Calculate AERIAL distance to HOME in 'units'
    Dim dLat = (lat_car - lat_home)
    dLat = Math.PI * dLat / 180
    Dim dLon = (lon_car - lon_home)
    dLon = Math.PI * dLon / 180
    Dim lat_home1 = Math.PI * lat_home / 180
    Dim lat_car1 = Math.PI * lat_car / 180
    Dim a = Math.Sin(dLat / 2) * Math.Sin(dLat / 2) + Math.Sin(dLon / 2) * Math.Sin(dLon / 2) * Math.Cos(lat_home1) * Math.Cos(lat_car1)
    Dim c = 2 * Math.Asin(Math.Sqrt(a))
    Dim distance_from_home = R * 2 * Math.Asin(Math.Sqrt(a))
    distance_from_home = Math.Round(distance_from_home, 3) ' Round on 3 decimals
    If Debug = true Then hs.writelog("to Home", distance_from_home & units)
    DevicesArrayV.Add(distance_from_home)
    DevicesArrayE.Add(units)
    DevicesArrayK.Add("Distance to Work")
    'Calculate AERIAL distance to WORK in 'units'
    Dim dLat1 = (lat_car - lat_work)
    dLat1 = Math.PI * dLat1 / 180
    Dim dLon1 = (lon_car - lon_work)
    dLon1 = Math.PI * dLon1 / 180
    Dim lat_work2 = Math.PI * lat_work / 180
    Dim lat_car2 = Math.PI * lat_car / 180
    If Debug = true Then hs.writelog("lat_work2", lat_work2)
    If Debug = true Then hs.writelog("lat_car2", lat_car2)
    Dim a1 = Math.Sin(dLat1 / 2) * Math.Sin(dLat1 / 2) + Math.Sin(dLon1 / 2) * Math.Sin(dLon1 / 2) * Math.Cos(lat_work2) * Math.Cos(lat_car2)
    Dim c1 = 2 * Math.Asin(Math.Sqrt(a1))
    If Debug = true Then hs.writelog("a1", a1)
    If Debug = true Then hs.writelog("c1", c1)
    Dim distance_from_work = R * 2 * Math.Asin(Math.Sqrt(a1))
    distance_from_work = Math.Round(distance_from_work, 3) ' Round on 3 decimals
    If Debug = true Then hs.writelog("to Work", distance_from_work)
    DevicesArrayV.Add(distance_from_work)
    DevicesArrayK.Add("Presence Home")
    Dim PresenceHomeRef = hs.GetDeviceRefByName(DVaddress & "_Presence Home")
    Dim PresenceHome = hs.DeviceValueEx(PresenceHomeRef)
    If Debug = true Then hs.writelog("Pres.HomeRef", PresenceHomeRef)
    If Debug = true Then hs.writelog("Pres.HomeVal", PresenceHome)
    If distance_from_home <= GeofenceHome' AND PresenceHome = 0
    DevicesArrayV.Add("100") ' Arrived at home when < xx units
    Elseif distance_from_home > GeofenceHome' AND PresenceHome = 100
    DevicesArrayV.Add("0") ' Away from home when > xx units
    Else
    DevicesArrayV.Add("0") ' Away when no calculation can be made
    End If
    DevicesArrayK.Add("Presence Work")
    Dim PresenceWorkRef = hs.GetDeviceRefByName(DVaddress & "_Presence Work")
    Dim PresenceWork = hs.DeviceValueEx(PresenceWorkRef)
    If Debug = true Then hs.writelog("Pres.WorkRef", PresenceWorkRef)
    If Debug = true Then hs.writelog("Pres.WorkVal", PresenceWork)
    If distance_from_work <= GeofenceWork' AND PresenceWork = 0
    DevicesArrayV.Add("100") ' Arrived at work when < xx units
    ElseIf distance_from_work > GeofenceWork' AND PresenceWork = 100
    DevicesArrayV.Add("0") ' Away from work when > xx units
    Else
    End If
    Dim odometer_night
    Dim odometer_nightRef
    Dim odometer_currRef
    Dim odometer_curr
    Dim totdistance_currRef
    Dim totdistance_currData
    ' 2 Extra devices, which are created in script "MySQL_Traccar_DailyDistance", will be updated here
    'Calculate daily distance
    ' Get value from last night
    odometer_nightRef = hs.GetDeviceRefByName(DVaddress & "_Odometer Night")
    odometer_night = hs.DeviceValueEx(odometer_nightRef)
    If debug = true Then hs.writelog("Odo-night", "odometer_night: " & odometer_nightRef & ": " & odometer_night)
    ' Get current Odometer value
    odometer_currRef = hs.GetDeviceRefByName(DVaddress & "_Odometer")
    If odometer_currRef <> -1
    odometer_curr = hs.DeviceValueEx(odometer_currRef)
    If debug = true Then hs.writelog("Odo-current", "odometer_curr: " & odometer_currRef & ": " & odometer_curr)
    Else
    totdistance_currRef = hs.GetDeviceRefByName(DVaddress & "_Totaldistance")
    totdistance_currData = hs.DeviceValueEx(totdistance_currRef)
    If debug = true Then hs.writelog("Totdist-current", "Totaldistance_curr: " & totdistance_currRef & ": " & totdistance_currData)
    End if
    ' Check if Battery value is lower than the Battery Monitor value. If true, then set Battery Alert to On.
    Dim battery_Ref = hs.GetDeviceRefByName(DVaddress & "_Battery")
    Dim battery_Data = hs.DeviceValueEx(battery_Ref)
    If Debug = true Then hs.writelog("battery_Data", battery_Data)
    Dim batterymonitor_Ref = hs.GetDeviceRefByName(DVaddress & "_Battery Monitor")
    Dim batterymonitor_Data = hs.DeviceValueEx(batterymonitor_Ref)
    If Debug = true Then hs.writelog("battmon_data", batterymonitor_Data)
    If (battery_Data <= batterymonitor_Data) Then
    Dim batteryalert_Ref = hs.GetDeviceRefByName(DVaddress & "_Battery Alert")
    hs.setDeviceValueByRef(batteryalert_Ref, 100, true)
    ' Dim url = "http://" & HS_IPAddress & "/JSON?request=controldevicebylabel&ref=" & batteryalert_Ref & "&label=On"
    ' Dim finalurl = hs.URLAction(url, "GET", "", "")
    If Debug = true Then hs.writelog("battery_alert", "greater")
    ' If Debug = true Then hs.writelog("alert_url", url)
    End If
    ' Check if Traccar Root device is created. If not, than create all devices.
    DevExists = hs.DeviceExistsAddress(DVaddress & "_Root Device", False)
    If Debug = true Then hs.writelog("DevExists", "Root device ref ID: " & DevExists)
    If DevExists = -1
    ' Create all child devices
    For i as Byte = 0 To DevicesArrayK.Count - 1
    Select Case i
    Case 0
    ' Create Traccar Root Device
    dv = hs.GetDeviceByRef(hs.NewDeviceRef(DVaddress &"_Root Device"))
    dv.Address(hs) = DVaddress & "_Root Device"
    BaseRef = dv.Ref(hs)
    hs.SetDeviceValueByRef(dv.Ref(hs), DevicesArrayK.Count - 1, True)
    hs.SetDeviceString(dv.Ref(hs), "No Status", True)
    Case 1 To DevicesArrayK.Count - 1
    ' Create child devices
    dv = hs.GetDeviceByRef(hs.NewDeviceRef(DVaddress & "_" & DevicesArrayK(i))) ' Fill Homeseer Name Column
    ' dv.Address(hs) = DVaddress & i ' Fill Homeseer DVaddress+counter in Address column
    ' dv.Address(hs) = DVaddress & DevicesArrayK(i) ' Fill Homeseer DVaddress+name in Address column
    dv.Address(hs) = DVaddress & "_" & i & "_" & DevicesArrayK(i) ' Fill Homeseer DVaddress+name in Address column. Counter(i) added for descent sorting
    End Select
    dv.Location2(hs) = "GPS" & "_" & DVAddress 'Floor
    dv.location(hs) = "Traccar" 'Room
    dv.Device_Type_String(hs) = DVaddress
    ' Set up the relationships between the devices
    If i = 0 Then
    root_dv = dv
    dv.Relationship(hs) = Enums.eRelationship.Parent_Root
    Else
    If root_dv IsNot Nothing Then root_dv.AssociatedDevice_Add(hs, dv.Ref(hs))
    dv.Relationship(hs) = Enums.eRelationship.Child
    dv.AssociatedDevice_Add(hs, BaseRef)
    End If
    ' Extend virtual devices with icons, value ranges etc
    Select Case DevicesArrayK(i)
    Case "Root Device"
    Dim SPair as VSPair
    Dim GPair as VGPair
    GPair = New VGPair
    GPair.PairType = VSVGPairType.Range
    GPair.RangeStart = -99999999999
    GPair.RangeEnd = 99999999999
    GPair.Graphic = "/images/HomeSeer/status/nostatus.gif"
    hs.DeviceVGP_AddPair(dv.Ref(hs), GPair)
    Case "Battery Monitor"
    Dim SPair As VSPair
    Dim GPair As VGPair
    ' hs.SetDeviceValue(dv.Ref(hs), "0")
    For index As Double = 2 To 8 Step 0.1
    SPair = New VSPair(HomeSeerAPI.ePairStatusControl.Control)
    SPair.PairType = VSVGPairType.SingleValue
    SPair.Value = Math.Round(index,1)
    SPair.RangeStatusDecimals = 1
    SPair.Render = Enums.CAPIControlType.Values
    SPair.Status = Format(Math.Round(index, 1), "0.0").ToString & " Volt"
    If Debug = true Then hs.writelog("BattMon", index & " - " & dv.Ref(hs))
    hs.DeviceVSP_AddPair(dv.Ref(hs), SPair)
    Next
    Case "Battery Alert"
    Dim SPair As VSPair
    Dim GPair As VGPair
    GPair = New VGPair
    GPair.PairType = VSVGPairType.SingleValue
    GPair.Set_Value = 0
    GPair.Graphic = "/images/HomeSeer/status/off.gif"
    GPair = New VGPair
    GPair.Set_Value = 100
    GPair.Graphic = "/images/HomeSeer/status/on.gif"
    SPair = New VSPair(HomeSeerAPI.ePairStatusControl.Both)
    SPair.Value = 0
    SPair.Status = "Off"
    SPair.ControlUse = HomeSeerAPI.ePairControlUse._Off
    SPair.Render = HomeSeerAPI.Enums.CAPIControlType.Button
    SPair.IncludeValues = True
    SPair.Value = 100
    SPair.Status = "On"
    SPair.ControlUse = HomeSeerAPI.ePairControlUse._On
    End Select
    dv.MISC_Set(hs, Enums.dvMISC.SHOW_VALUES)
    Next
    ' Start Create Traccar DailyDistance event
    Dim EventRef as Integer
    Dim OldEventRef as Integer
    Dim EvTime as Date
    Dim EventExists as Integer
    EventExists = hs.GetEventRefByName(strEventName)
    If EventExists = -1
    ' Create the new Event
    EventRef = hs.NewEventEx(strEventName, strEventGroup, "")
    ' Status of Event
    hs.EnableEventByRef(EventRef)
    ' ' Set Event frequency to recurring 20 seconds // ... days, hours, minutes, seconds, milliseconds.
    ' Dim span as TimeSpan = New TimeSpan(0, 0, 0, 20, 0)
    ' hs.EventSetRecurringTrigger(EventRef, span, false, false)
    ' Set Event frequency to once per dag // at 23:59:05 hrs.
    hs.EventSetTimeTrigger(EventRef,"23:59:05") ' Will be saved also as 11:59:05 PM
    ' Log created event details
    Try
    hs.AddActionRunScript(EventRef, strEventLaunchScript, strEventLaunchByNameProc, strEventLaunchProcParams)
    If Debug = true Then hs.writelog(ScriptName , "New Event " & strEventName & " created.")
    If Debug = true Then hs.writelog(ScriptName , "Event Ref: " + Str(EventRef))
    If Debug = true Then hs.writelog(ScriptName , "Event Group: " + strEventGroup)
    If Debug = true Then hs.writelog(ScriptName , "Event Type: " + strEventLaunchByRefProc)
    If Debug = true Then hs.writelog(ScriptName , "Event Script: " + strEventLaunchScript)
    ' If Debug = true Then hs.writelog(ScriptName , "Event Calls this Procedure: " + strEventLaunchByNameProc )
    ' If Debug = true Then hs.writelog(ScriptName , "With These Parameters: " + strEventLaunchProcParams )
    Catch ex as Exception
    hs.writelog(ScriptName, String.Format("Error adding event action to event '{0}': {1}", strEventName, ex.Message))
    Throw Ex
    End Try
    ' Run event once, so the table will be created immediately (and additional sub device will be created as well)
    hs.TriggerEvent("Traccar_DailyDistance")
    End If
    ' EndCreate Traccar DailyDistance event
    End If
    ' End creating devices and events
    ' Update virtual devices
    If Debug = true Then hs.writelog("Array: "&i, DevicesArrayK(i) & " - " & DevicesArrayV(i) & " " & DevicesArrayE(i))
    Dim update = hs.GetDeviceRefByName(DVaddress & "_" & DevicesArrayK(i))
    ' If Debug = true Then hs.writelog("updateVal", update)
    ' Check if array key is already available as virtual device. If not, than create it.
    ' If Debug = true Then hs.writelog("To Update", DVaddress & "_" & DevicesArrayK(i))
    If update = -1 ' Virtual device doesn't exists
    ' In the Traccar Root device, the total device counter value is stored. Based on this number, the new devices will get the followup number
    Dim RootCounterRef = hs.DeviceExistsAddress(DVaddress & "_Root Device", False)
    Dim RootCounter as Integer
    If RootCounterRef > 0
    RootCounter = hs.Devicevalue(RootCounterRef) + 1
    If Debug = true Then hs.writelog("RootCounter", RootCounter)
    End If
    If Debug = true Then hs.writelog("DevNotExists", DVaddress & "_" & DevicesArrayK(i))
    dv.Address(hs) = DVaddress & "_" & RootCounter & "_" & DevicesArrayK(i) ' Fill Homeseer DVaddress+name in Address column. Counter(i) added for descent sorting
    Dim SPair as VSPair
    Dim GPair as VGPair
    GPair = New VGPair
    GPair.Graphic = "/images/Traccar/5-x-5_trans_spacer.gif"
    'Save RootCounter in Root device
    hs.SetDeviceValueByRef(RootCounterRef, RootCounter, true)
    End If
    Dim inttest as Integer
    Dim doubletest as Double
    Try ' True when value is an Integer
    inttest = Convert.ToInt32(DevicesArrayV(i))
    hs.SetDeviceValueByRef(update, DevicesArrayV(i), true)
    hs.SetDeviceString(update, DevicesArrayV(i) & DevicesArrayE(i), true)
    Catch ' Value isn't an Integer
    End Try
    Try ' True when value is a Double
    doubletest = Convert.ToDouble(DevicesArrayV(i))
    Catch ' Value isn't a Double
    End Try
    Next
    Dim odometer_daily
    ' Calculate daily distance
    Dim odometer_dailyRef = hs.GetDeviceRefByName(DVaddress & "_Odometer Daily")
    If Debug = true Then hs.writelog("DevExists", "Odometer Daily device ref ID: " & odometer_dailyRef)
    ' Check if "Odometer" exists, if not, take value from "Totaldistance"
    odometer_daily = (odometer_curr - odometer_night)
    odometer_daily = Math.Round(odometer_daily, 3)
    If Debug = true Then hs.writelog("Odo-daily", "odometer_daily: " & odometer_dailyRef & ": " & odometer_daily)
    Else
    ' totdistance_currRef = hs.GetDeviceRefByName(DVaddress & "_Totaldistance")
    totdistance_currRef = hs.GetDeviceRefByName(DVaddress & "_Io16")
    If Debug = true Then hs.writelog("Totdist-data", totdistance_currData)
    odometer_daily = ((totdistance_currData - odometer_night))/1000
    If Debug = true Then hs.writelog("Totdist-daily", "Totaldistance: " & totdistance_currRef & ": " & odometer_daily)
    End If
    hs.SetDeviceValueByref(odometer_dailyRef, odometer_daily, true)
    hs.SetDeviceString(odometer_dailyRef, odometer_daily & units, true)
    If Debug = true Then hs.writelog("XXXXX", "XXXXXXXXXXXXXXXXX End " & DVaddress & " XXXXXXXXXXXXXXXXX")
    ' Clear arrays and variables
    DevicesArrayD.Clear()
    DevicesArrayN.Clear()
    DevicesArrayK.Clear()
    DevicesArrayV.Clear()
    DevicesArrayE.Clear()
    DVAddress = Nothing
    streetview_store = Nothing
    streetview_open = Nothing
    streetview_web = Nothing
    odometer_dailyRef = Nothing
    odometer_daily = Nothing
    odometer_curr = Nothing
    odometer_night = Nothing
    Columnname = Nothing
    Columnvalue = Nothing
    batterymonitor_old_data = Nothing
    End While
    End If
    conn.Close()
    conn1.Close()
    conn.Dispose()
    conn1.Dispose()
    Catch myerror as MySqlException
    hs.writelog("Traccar", "Error Connecting to Database " & DBtraccar & ": " & myerror.Message)
    If conn.State = ConnectionState.Open Then
    If Debug = true Then hs.writelog("Traccar", "Connection to database " & DBtraccar & " will be closed now.")
    conn.Close()
    conn.Dispose()
    If Debug = true Then hs.writelog("Traccar", conn.State)
    Else
    If Debug = true Then hs.writelog("Traccar", "Connection to database " & DBtraccar & "is already closed.")
    End If
    End Try
    End Sub
    ' Sub ButtonPress(Input As Object)
    ' Dim Debug as Boolean = true ' true/false
    ' Dim DevID As Integer = Input(0) 'Integer - The device reference ID.
    ' Dim ScriptCallParm As String = Input(1) 'String - Script Parm Passed from Button
    ' Dim dv1 = hs.GetDeviceByRef(DevID)
    ' Dim DevTypePid = dv1.Device_Type_String(hs)
    ' If Debug = True Then hs.Writelog("AddButton", ScriptCallParm & " has been pressed!")
    ' If Debug = True Then hs.Writelog("AddButton", "DevID: " & DevID)
    ' If Debug = True Then hs.Writelog("AddButton", "DevTypePid: " & DevTypePid)
    ' ' Reset
    ' If ScriptCallParm = "ButtonReset" Then
    ' hs.SetDeviceValueByRef(DevID, "Off", True)
    ' ' hs.SetDeviceString(DevID, hs.DeviceString(DevID)+1, True)
    ' End If
    ' End Sub
    I'm doing some Traccar integration into HS (toying with the idea of writing a plugin) and from reading that script it appears a little complex as it is reading from the database rather than the API (I would've thought most of this functionality was available from the HTTP API which is much easier to deal with).
    There are a couple of places that error might be caused and it appears that it is an error caused when a time is queried, what I might suggest is a few hs.writelog before/after a couple of the SQL queries and see if you get those statements in the HS log, that will help you narrow down where it is. I'd put £5 on it being an issue around time zone or date formatting being different.
      I'm not sure why Rutg3r decided to use this method of integration but he's much cleverer than I when it comes to this stuff. I did think an easy way may be available but perhaps it's more limiting in some way.
      I was wondering if its possible to push events to homeseer via traccar but I'm not involved enough to look at this stuff.
      A plugin would be cool, it's definately crying out for one.
      I'll try what you suggest and post back.
      thanks.
        So I tried inserting some writelogs at various places, and whether or not this is relevant I don't know.
        It seems I can get a log write-out right before the following but nothing after as it then errors...
        Dim myAdapterG As New MySqlDataAdapter
        Dim myDataG As MySqlDataReader
        I don't know why this would cause an error as it's just declaring stuff, so maybe not this problem? But it won't run past this point.
          Is the MySQL server running, is the database instance 'traccar' valid, is the username/password correct?
          Looks like your opening the same database twice (connections 'conn' and 'conn1'). Almost certainly a Bad Idea.
          'myCommand.ExecuteNonQuery()' is executing a database query, not 'just declaring stuff'.
            What sort of traccar integration would be in your desires? I'm aware other plugins are out there for it but are multi technology whereas I prefer to have plugins that stick to one thing. I'm keen to not make it too complex as really you won't beat using their UI.
              I've got Rutg3r's script working.... and it works reasonably well. I think anything that doesmt work like certain devices don't update, is down to unsupported parameters with a user's specific tracking device.
              Rutg3r's integration with traccar is pretty useful and he's put a lot of work into that script. For me however, it's too much and I don't need all the clutter such as all the extra devices that get created like rssi, priority, events etc. Clearly they will be of use to some people and you can actually just afaik delete the ones you don't want and they don't come back unless you delete the root device.
              Google maps integration is nice but I don't need it. Here is what I was looking into prior to using Rutg3r's script:
              Having a script running every X seconds to pull data from the traccar database has it's benefits, but the problem with this approach is that the devices in homeseer only get updated each run of the script. Tracking devices generally submit their coordinates and other data every X seconds depending on configuration. So with this current setup we technically have two possible delays before we see the updated device a in homeseer, the latter being uncontrollable due to the way the gps trackers work.
              I was looking at ways of pushing data from traccar into homeseer, rather than fetching it on a schedule. This of course would instantly update the HS devices. Traccar has an open source api afaik and also supports json to some degree, though I'm not sure it will provide the necessary.
              That would be the deal breaker for me, if a HS plugin can't receive instant device updates from traccar then I can't see there would be any benefit over Rutg3r's script.
              Another useful feature Rutg3r uses is built-in geofence for home and work, though I personally don't use this as intended. I prefer, like you, to keep all of that within traccar including geofences, and the best method imo is to have a virtual device in homeseer that is updated whenever those geofences are breached.
              I'm currently trying to make Rutg3r's script work for me in that respect. I'm not interested in the two home and work geofences per se, I simply want to create events that fire when I enter an approx distance to home, the final one being to turn on my outside lights.
              There's likely more but that's all I can think right now.
              Like I said already, Rutg3r's script is almost perfect for my needs, but a few things could definately be improved. I'm not sure if the limitations here are actually the traccar software.
              On a related note, I'm more than happy to demo any betas you have and I'm also happy to pay for a plugin if it has my requirements.
              cheers
                cheers
                Thanks for the steer, I had pretty much the same idea - my needs in HS are simple (perhaps too simple!) and primarily is where my devices are and if they are/are not in geofences (and immediate notification of in/out). If I need anything else then I would use the UI for Traccar.
                The immediate notification should be possible with the websocket API and this is what I intended to use, I will drop you a message if I proceed.
                  Nice one. I think there will be plenty of interest.
                  Trackers are cheap, accurate and a good way linking in vehicles to HS.
                  Hope you can go ahead.
                    Not sure from reading this if you got what you needed, but two things I have found very helpful debugging scripts:
                    1. Using tenscripting (which you said you had tried) and running the script within the development environmebnt with breakpoints set.
                    2. Surround anything suspect with a try .. catch .. end try:
                    try
                    all your code
                    catch ex as exception
                    hs.writelog("ERROR", "Exception: " & ex.tostring)
                    end try
                    That should tell you the nature of the error and the line on which it occurred.
                    Note that if the exception is thrown in a function without a try .. catch...end try, it will simply give you the line number of hte call to hte function. You need a try inside the generating the error.
