Getting the system.core error with script
    Compiling script C:\PROGRAM FILES (X86)\HOMESEER HS3\scripts\ClimaCellConnect.vb: Character is not valid.
    Jun-20 4:55:19 PM Error Compiling script C:\PROGRAM FILES (X86)\HOMESEER HS3\scripts\ClimaCellConnect.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    I've posted the script below. It works fine in visual studio using tenholder's program. I've had other scripts work fine with system.net namespace. Is it the system.collections.generic namespace? Any insight would be appreciated.
    Imports System.Web.Script.Serialization
    Imports System.Net
    Imports System.Collections.Generic
    Public Class ClimaCellConnect
    Public Sub Main(ByVal Parms As String)
    ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12
    Dim json As New JavaScriptSerializer
    Dim climaUrlPage = "lat=41.8255421&lon=-88.2921317&unit_system=us&end_time=" +
    "&fields%5B%5D=temp&fields%5B%5D=feels_like&fields%5B%5D =pre cipitation_probability&fields%5B%5D=precipitation_accumulati on&fields%5B%5D=sunrise&fields%5B%5D=sunset" +
    "&fields%5B%5D=weather_code&apikey="
    'Dim lat = "lat=41.8255421&" '21
    'Dim longitude = "lon=--88.2921317" '17
    Dim climaUrl = "https://api.climacell.co/v3/weather/forecast/daily?"
    Dim secret_key = "SwVvgMAjaNA******************"
    Dim request As HttpWebRequest = CType(HttpWebRequest.Create(climaUrl + climaUrlPage + secret_key), HttpWebRequest)
    request.Proxy = Nothing
    request.UserAgent = "Test"
    request.ContentType = "application/json"
    Dim response As HttpWebResponse = CType(request.GetResponse, HttpWebResponse)
    Dim response_stream As System.IO.Stream = response.GetResponseStream
    Dim stream_reader As New System.IO.StreamReader(response_stream)
    Dim Data As String = stream_reader.ReadToEnd
    stream_reader.Close()
    'Dim dsData As List(Of WeatherInfo)
    Dim weatherInfo = json.Deserialize(Of List(Of WeatherInfo))(Data)
    'Dim weatherInfo = JsonConvert.DeserializeObject(Of List(Of WeatherInfo))(Data)
    'JsonConvert.DeserializeObject<List<WeatherInfo>>(stringJson )
    SetHomeseerDevices(weatherInfo)
    End Sub
    Public Sub SetHomeseerDevices(ByVal weatherData As List(Of WeatherInfo))
    hs.SetDeviceValueByRef(1426, weatherData(0).temp(1).max.value, True)
    hs.SetDeviceString(1426, weatherData(0).temp(1).max.value.ToString(), True)
    hs.SetDeviceValueByRef(1429, weatherData(1).temp(1).max.value, True)
    hs.SetDeviceString(1429, weatherData(1).temp(1).max.value.ToString(), True)
    hs.SetDeviceValueByRef(1427, weatherData(0).temp(0).min.value, True)
    hs.SetDeviceString(1427, weatherData(0).temp(0).min.value.ToString(), True)
    hs.SetDeviceValueByRef(1430, weatherData(1).temp(0).min.value, True)
    hs.SetDeviceString(1430, weatherData(1).temp(0).min.value.ToString(), True)
    hs.SetDeviceValueByRef(1423, weatherData(0).precipitation_probability.value, True)
    hs.SetDeviceString(1423, $"{weatherData(0).precipitation_probability.value.ToStrin g() }% chance", True)
    hs.SetDeviceValueByRef(1428, weatherData(1).precipitation_probability.value, True)
    hs.SetDeviceString(1428, $"{weatherData(1).precipitation_probability.value.ToStrin g() }% chance", True)
    hs.SetDeviceValueByRef(1425, weatherData(0).precipitation_accumulation.value, True)
    hs.SetDeviceString(1425, $"{weatherData(0).precipitation_accumulation.value.ToStri ng( )} inches", True)
    hs.SetDeviceString(1432, $"{weatherData(0).weather_code.value}", True)
    hs.SetDeviceString(1433, $"{weatherData(1).weather_code.value}", True)
    End Sub
    End Class
    Public Class Min
    Public Property value As Double
    Public Property units As String
    End Class
    Public Class Max
    End Class
    Public Class Temp
    Public Property observation_time As DateTime
    Public Property min As Min
    Public Property max As Max
    End Class
    Public Class PrecipitationAccumulation
    End Class
    Public Class PrecipitationProbability
    Public Property value As Integer
    End Class
    Public Class FeelsLike
    Public Property min As Dictionary(Of Object, Object)
    Public Property max As Dictionary(Of Object, Object)
    End Class
    Public Class Sunrise
    Public Property value As DateTime
    End Class
    Public Class Sunset
    End Class
    Public Class WeatherCode
    Public Property value As String
    End Class
    Public Class ObservationTime
    End Class
    Public Class WeatherInfo
    Public Property temp As List(Of Temp)
    Public Property precipitation_accumulation As PrecipitationAccumulation
    Public Property precipitation_probability As PrecipitationProbability
    Public Property feels_like As List(Of FeelsLike)
    Public Property sunrise As Sunrise
    Public Property sunset As Sunset
    Public Property weather_code As WeatherCode
    Public Property observation_time As ObservationTime
    Public Property lat As Double
    Public Property lon As Double
    End Class
    Your actual error is "Character is not valid.", due to the "$" characters on this line and four subsequent instances.
    Once these are corrected you may get a bunch of "Reference to a non-shared member requires an object reference." errors, apparently due to the way you're trying to dereference the JSON, starting at the line
    The 'System.Core' message (its actually a warning, not an error), is a bogus message generated on every script compilation. Since it's only a warning, it's only displayed when there are subsequent compilation errors. The wrapper that HST uses includes the line 'Imports System.Core' which apparently is invalid in the context that the compiler is called.
      Thanks, don’t know how I missed the $ symbol. On your second point, how should I be referencing the json? Are you saying I should make it a variable first?
        It looks like the errors I was seeing "Reference to a non-shared member requires an object reference." can be eliminated by removing the line near the start
        and it's associated 'End Class'.
        Those errors weren't due to the JSON dereferencing after all, rather the class declaration was isolating the definition of the 'hs' object so it wasn't available inside the declared class.
        With those two lines and the "$" characters removed I get a clean compile.
          If you were testing using tenScripting, I'm surprised the $ errors weren't caught. Also, the Class and Class End statements should have been stripped out of your script if you used the tenScripting Export function. Let me know if there is an apparent tenScripting problem.
          tenholde
            Thanks for looking at it, got it up and working now which will replace now Apple's DarkSky api.
              Yeah, weird. It works with tenScripting using string interpolation with the $ in visual studio. I had migrated this script from C# to vb.net. I guess homeseer doesn't allow string interpolation but tenScripting does?
                Might have to do with what version of the. Net framework HS is targeting. HS provides very little support to the scripting environment as they feel everything can now be done with events.
                I'm close to having CSharp support in tenScripting and am looking for testers
                tenholde
                  ... which will replace now Apple's DarkSky api.
                  Cool, looks interesting. I've been checking out OpenWeatherMap, visualcrossing.com, weatherbit.io. I'll take a look at this one as well!
                    Great! I’d be happy to test
                      I used this one mainly as it included precipitation probability, seems like a lot don’t.
                        Thanks for all the info guys. I had been looking for a decent Darksky replacement for some time now. ClimaCell and Aeris were on my list. Will apply this info to check out Climacell first.
