Getting the system.core error with script
Thanks for all the info guys. I had been looking for a decent Darksky replacement for some time now. ClimaCell and Aeris were on my list. Will apply this info to check out Climacell first.
Originally posted by zwolfpack View Post
Cool, looks interesting. I've been checking out OpenWeatherMap, visualcrossing.com, weatherbit.io. I'll take a look at this one as well!
Originally posted by tenholde View Post
Might have to do with what version of the. Net framework HS is targeting. HS provides very little support to the scripting environment as they feel everything can now be done with events.
I'm close to having CSharp support in tenScripting and am looking for testers
Originally posted by jayman13 View Post
Yeah, weird. It works with tenScripting using string interpolation with the $ in visual studio. I had migrated this script from C# to vb.net. I guess homeseer doesn't allow string interpolation but tenScripting does?
Originally posted by tenholde View PostIf you were testing using tenScripting, I'm surprised the $ errors weren't caught. Also, the Class and Class End statements should have been stripped out of your script if you used the tenScripting Export function. Let me know if there is an apparent tenScripting problem.
Originally posted by zwolfpack View PostIt looks like the errors I was seeing "Reference to a non-shared member requires an object reference." can be eliminated by removing the line near the start
Code:Public Class ClimaCellConnect
Those errors weren't due to the JSON dereferencing after all, rather the class declaration was isolating the definition of the 'hs' object so it wasn't available inside the declared class.
With those two lines and the "$" characters removed I get a clean compile.
Thanks, don’t know how I missed the $ symbol. On your second point, how should I be referencing the json? Are you saying I should make it a variable first?
Your actual error is "Character is not valid.", due to the "$" characters on this line and four subsequent instances.
Code:hs.SetDeviceString(1423, $"{weatherData(0).precipitation_probability.value.ToStrin g() }% chance", True)
Code:hs.SetDeviceValueByRef(1426, weatherData(0).temp(1).max.value, True)
Compiling script C:\PROGRAM FILES (X86)\HOMESEER HS3\scripts\ClimaCellConnect.vb: Character is not valid. Jun-20 4:55:19 PM Error Compiling script C:\PROGRAM FILES (X86)\HOMESEER HS3\scripts\ClimaCellConnect.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
I've posted the script below. It works fine in visual studio using tenholder's program. I've had other scripts work fine with system.net namespace. Is it the system.collections.generic namespace? Any insight would be appreciated.
Imports System.Web.Script.Serialization
Imports System.Net
Imports System.Collections.Generic
Public Sub Main(ByVal Parms As String)
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12
Dim json As New JavaScriptSerializer
Dim climaUrlPage = "lat=41.8255421&lon=-88.2921317&unit_system=us&end_time=" +
"&fields%5B%5D=temp&fields%5B%5D=feels_like&fields%5B%5D =pre cipitation_probability&fields%5B%5D=precipitation_accumulati on&fields%5B%5D=sunrise&fields%5B%5D=sunset" +
"&fields%5B%5D=weather_code&apikey="
'Dim lat = "lat=41.8255421&" '21
'Dim longitude = "lon=--88.2921317" '17
Dim climaUrl = "https://api.climacell.co/v3/weather/forecast/daily?"
Dim secret_key = "SwVvgMAjaNA******************"
Dim request As HttpWebRequest = CType(HttpWebRequest.Create(climaUrl + climaUrlPage + secret_key), HttpWebRequest)
request.Proxy = Nothing
request.UserAgent = "Test"
request.ContentType = "application/json"
Dim response As HttpWebResponse = CType(request.GetResponse, HttpWebResponse)
Dim response_stream As System.IO.Stream = response.GetResponseStream
Dim stream_reader As New System.IO.StreamReader(response_stream)
Dim Data As String = stream_reader.ReadToEnd
stream_reader.Close()
'Dim dsData As List(Of WeatherInfo)
Dim weatherInfo = json.Deserialize(Of List(Of WeatherInfo))(Data)
'Dim weatherInfo = JsonConvert.DeserializeObject(Of List(Of WeatherInfo))(Data)
'JsonConvert.DeserializeObject<List<WeatherInfo>>(stringJson )
SetHomeseerDevices(weatherInfo)
End Sub
Public Sub SetHomeseerDevices(ByVal weatherData As List(Of WeatherInfo))
hs.SetDeviceString(1426, weatherData(0).temp(1).max.value.ToString(), True)
hs.SetDeviceValueByRef(1429, weatherData(1).temp(1).max.value, True)
hs.SetDeviceString(1429, weatherData(1).temp(1).max.value.ToString(), True)
hs.SetDeviceValueByRef(1427, weatherData(0).temp(0).min.value, True)
hs.SetDeviceString(1427, weatherData(0).temp(0).min.value.ToString(), True)
hs.SetDeviceValueByRef(1430, weatherData(1).temp(0).min.value, True)
hs.SetDeviceString(1430, weatherData(1).temp(0).min.value.ToString(), True)
hs.SetDeviceValueByRef(1423, weatherData(0).precipitation_probability.value, True)
hs.SetDeviceValueByRef(1428, weatherData(1).precipitation_probability.value, True)
hs.SetDeviceString(1428, $"{weatherData(1).precipitation_probability.value.ToStrin g() }% chance", True)
hs.SetDeviceValueByRef(1425, weatherData(0).precipitation_accumulation.value, True)
hs.SetDeviceString(1425, $"{weatherData(0).precipitation_accumulation.value.ToStri ng( )} inches", True)
hs.SetDeviceString(1432, $"{weatherData(0).weather_code.value}", True)
hs.SetDeviceString(1433, $"{weatherData(1).weather_code.value}", True)
End Sub
End Class
Public Class Min
Public Property value As Double
Public Property units As String
End Class
Public Class Max
End Class
Public Class Temp
Public Property observation_time As DateTime
Public Property min As Min
Public Property max As Max
End Class
Public Class PrecipitationAccumulation
End Class
Public Class PrecipitationProbability
Public Property value As Integer
End Class
Public Class FeelsLike
Public Property min As Dictionary(Of Object, Object)
Public Property max As Dictionary(Of Object, Object)
End Class
Public Class Sunrise
Public Property value As DateTime
End Class
Public Class Sunset
End Class
Public Class WeatherCode
Public Property value As String
End Class
Public Class ObservationTime
End Class
Public Class WeatherInfo
Public Property temp As List(Of Temp)
Public Property precipitation_accumulation As PrecipitationAccumulation
Public Property precipitation_probability As PrecipitationProbability
Public Property feels_like As List(Of FeelsLike)
Public Property sunrise As Sunrise
Public Property sunset As Sunset
Public Property weather_code As WeatherCode
Public Property observation_time As ObservationTime
Public Property lat As Double
Public Property lon As Double
End Class
Tags: None
