Terminating a script
    Hi
    I have a script that ...
    does stuff :-))
    Waits 5 seconds
    does stuff...
    I wish to 'kill' the script based on an event not disable it - but terminate it immediately.
    If I just disable it ; it could still be at the wait for 5 seconds and hence continues the script.
    If that's not possible any other suggestions for ending an event script welcome.
    Cheers
    To further confused myself!!
    If a script is running and it does
    Wait 5 seconds
    During that time another event\script disables the original script ( as it's still waiting 5 seconds ); after the wait if I do
    isScriptRunning will it be yes or no?. It IS still running but it has been disabled.....
    Just thinking if I stuck isScriptRunning after the wait ( and it was false ) then I could exit the script early....
      What you describe all seems messy....however to answer you question.
      You can't just terminate a script from another. To do what you want, you need to monitor a variable which is available to both scripts. This could be a global variable, an ini file entry or a virtual device.
      The following code demonstrates using global variables:
      Sub Main(ByVal Parm As Object)
      hs.CreateVar("stopme")
      hs.SaveVar("stopme","0")
      ' You first code here
      ' Wait 5 secs
      For P As Integer = 1 To 50
          If hs.GetVar("stopme") = "1" Then Exit Sub
          hs.WaitSecs(0.1)
      Next
      ' Your second code here
      End Sub
      Your second script:
      'Use this line to exit other script
      hs.SaveVar("stopme", "1")
      End Sub
      Hopefully you can see that if you set the global variable "stopme" to "1", it will cause the other script to jump out of its 5 second loop and exit the script.
      Jon
        I do something very similar to this for watering my lawn in cycles. It will kill the script and then I run another event to shutoff the zone that is watering. Jon's is a more elegant solution but also more resource intensive.
         Do While dvCode < 10
        KillMe = hs.DeviceValue(451)   '<---------- The boolean device to control the script running
        If KillMe = 1 Then 'Told to Die
        hs.SetDeviceValueByRef(451, 0, True) 'Reset the Device so Watering can run
        hs.CounterReset("Zone Counter") 'Set the Zone Number to 0
        hs.CounterReset("WateringCycle") 'Set the Cycle Number to 0
        hs.TriggerEvent("Shut Off Timers")
        Exit Sub 'Exit the Subroutine
        End If
        hs.TimerReset("Watering Time")
        dCode = 7681 + dvCode
        CallCAPI(dvRef, dString(dvCode)) 'Turn on for xx minutes
        hs.SetDeviceValuebyRef(dvRef, dCode, True) ' Set the Device value
        hs.WaitSecs(ZoneTime)
        CallCAPI(dvRef, "Off") 'Turn off
        hs.SetDeviceValuebyRef(dvRef, 0, True) ' Show it as Off
        hs.WaitSecs(2)
        dvCode = dvCode + 1
        hs.CounterIncrement("Zone Counter")
        Loop
          ' Wait 5 secs
              hs.WaitSecs(0.1)
          Next
          End Sub
          Your second script:
          End Sub
          Yep my approach was messy . That’s due to being new to HS .
          Your solution is much cleaner and neater .
          Will use it - can’t see any issues with it .
          Much appreciated! 👍
            ' Wait 5 secs
                hs.WaitSecs(0.1)
            Next
            End Sub
            Your second script:
            End Sub
            Just 1 question
            The global var will get created multiple times . Presumably creating the same variable just creates one iteration of it ? . Not sure how global vars ‘exist’ in HS .
              Originally posted by Pocster View Post
              Just 1 question
              No, it is only created once and ignored if already created. It stops errors if you try to save to a Global Variable that does not exist.
              Jon
                Thanks !
                  I generally create all of my global variables in startup.vb. This way I know they are available immediately when the system reboots. It allows you to use the global variables in hstouch. I also read all my .ini files and populate the data on startup.
                    Not heard of that .
                    So startup.vb is automatically started at boot ? Do I need to specify / configure it somewhere ??
                    Cheers
                      Look on your custom page as shown below. The file should be in ..../scripts.
Name:	Screenshot from 2020-06-25 09-13-14.png
                      Here is the file
                      IMPORTS System.IO
                      IMPORTS System.net
                      ' This is the startup script
                      ' It is run once when HomeSeer starts up
                      ' You may also have Startup.vb and it will be run instead of this script.
                      Sub Main(Parm As Object)
                      Dim SpeakClients As String = ""
                      Dim errst
                      Dim FQPN As String = "Watering6120.ini"
                      Dim ZoneTime As Integer = hs.GetINISetting("Watering", "ZoneTime", "540", FQPN) 'Create a default
                      Dim FlowerTime As Integer = hs.GetINISetting("Watering", "FlowerTime", "960", FQPN)'Create a default
                      Dim sCycles As Integer = hs.GetINISetting("Watering", "SoakCycles", "1", FQPN) 'Create a default
                      'Use simplified method to calculate the Epoch time representing the start of the seasons
                      ' Used the Method given at: https://www.aa.quae.nl/en/antwoorden/seizoenen.html
                      'This is good until the year 2100 within a margin of error of 19 minutes.
                      'This is in UCT (GMT or Zulu)
                      Dim FQPN1 As String = "Seasons.ini"
                      Dim CurrentYear As DateTime = Now()
                      Dim Year = CInt(CurrentYear.Year)
                      Dim Spring As Long = hs.GetINISetting("Season", "Spring", "1111318399", FQPN1) 'Create a default
                      Dim Summer As Long = hs.GetINISetting("Season", "Summer", "1119335951", FQPN1) 'Create a default
                      Dim Fall As Long = hs.GetINISetting("Season", "Fall", "1127427394", FQPN1) 'Create a default
                      Dim Winter As Long = hs.GetINISetting("Season", "Winter", "1135190091", FQPN1) 'Create a default
                      'These are the Dates and time for the Start of Spring, Summer, Fall and Winter.
                      Dim ESpring As Long = 1111318399
                      Dim ESummer As Long = 1119335951
                      Dim EFall As Long = 1127427394
                      Dim EWinter As Long = 1135190091
                      'These are the seconds for each type of year.
                      Dim SpringYear As Long = 31556942
                      Dim SummerYear As Long = 31556877
                      Dim FallYear As Long = 31556911
                      Dim WinterYear As Long = 31556973
                      'The timespamps for the current year
                      Dim CurrentSpring As Long = ESpring + (Year-2005)*SpringYear
                      Dim CurrentSummer As Long = ESummer + (Year-2005)*SummerYear
                      Dim CurrentFall As Long = EFall + (Year-2005)*FallYear
                      Dim CurrentWinter As Long = EWinter + (Year-2005)*WinterYear
                      Dim sCurrentSpring, sCurrentSummer, sCurrentFall, SCurrentWinter As String
                      Dim MyTime As DateTime
                      Dim MyETime As New DateTime(1970, 1, 1)
                      'Save to the .ini file
                      hs.SaveINISetting("Season", "Spring", CStr(CurrentSpring), FQPN1)
                      hs.SaveINISetting("Season", "Summer", CStr(CurrentSummer), FQPN1)
                      hs.SaveINISetting("Season", "Fall", CStr(CurrentFall), FQPN1)
                      hs.SaveINISetting("Season", "Winter", CStr(CurrentWinter), FQPN1)
                      'Create and save to global variables
                      errst = hs.CreateVar("CurrentSpring")
                      errst = hs.CreateVar("CurrentSummer")
                      errst = hs.CreateVar("CurrentFall")
                      errst = hs.CreateVar("CurrentWinter")
                      'Now in String format
                      errst = hs.CreateVar("sCurrentSpring")
                      errst = hs.CreateVar("sCurrentSummer")
                      errst = hs.CreateVar("sCurrentFall")
                      errst = hs.CreateVar("sCurrentWinter")
                      errst=hs.SaveVar("CurrentSpring", CurrentSpring)
                      errst=hs.SaveVar("CurrentSummer", CurrentSummer)
                      errst=hs.SaveVar("CurrentFall", CurrentFall)
                      errst=hs.SaveVar("CurrentWinter", CurrentWinter)
                      'Convert to string
                      MyTime = MyETime.AddSeconds(CurrentSpring)
                      sCurrentSpring = MyTime.ToString("MM/dd/yyyy HH:mm:ss")
                      MyTime = MyETime.AddSeconds(CurrentSummer)
                      sCurrentSummer = MyTime.ToString("MM/dd/yyyy HH:mm:ss")
                      MyTime = MyETime.AddSeconds(CurrentFall)
                      sCurrentFall = MyTime.ToString("MM/dd/yyyy HH:mm:ss")
                      MyTime = MyETime.AddSeconds(CurrentWinter)
                      sCurrentWinter = MyTime.ToString("MM/dd/yyyy HH:mm:ss")
                      errst = hs.SaveVar("sCurrentSpring", sCurrentSpring)
                      errst = hs.SaveVar("sCurrentSummer", sCurrentSummer )
                      errst = hs.SaveVar("sCurrentFall", sCurrentFall)
                      errst = hs.SaveVar("sCurrentWinter", SCurrentWinter)
                      'Back to the original script
                      hs.WriteLog("Startup", "Scripting is OK and is now running Startup.vb")
                      SpeakClients = hs.GetInstanceList
                      If SpeakClients Is Nothing Then SpeakClients = ""
                      If String.IsNullOrEmpty(SpeakClients.Trim) Then
                      hs.WriteLog("Startup", "(Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...")
                      ' There are no connected speaker clients, so let's wait 30 seconds
                      ' (the default re-connect interval for a speaker client)
                      ' to see if we can get one connected, otherwise the two speak
                      ' commands below will not be heard.
                      hs.WaitSecs(1)
                      Dim Start As Date = Now()
                      Do
                      hs.WaitSecs(1)
                      Else
                      Exit Do
                      End If
                      Loop Until Now.Subtract(Start).TotalSeconds > 30
                      End If
                      ' Speak - comment the next line if you do not want HomeSeer to speak at startup.
                      ' hs.Speak("Home Seer Restarted - House Ready", True)
                      ' speak the port the web server is running on
                      'Dim port As String = hs.GetINISetting("Settings", "gWebSvrPort", "")
                      'If port <> "80" Then
                      'hs.Speak("Web server port number is " & port)
                      'End If
                      ' You may add your own commands to this script.
                      ' See the scripting section of the HomeSeer help system for more information.
                      ' You may access help by going to your HomeSeer website and clicking the HELP button,
                      ' or by pointing your browser to the /help page of your HomeSeer system.
                      'Call Additonal scripts - jlg 5/7/2019
                      hs.RunScript("Easter.vb",True,True) 'Find out the date for easter, Create a Global variable and write the date to it.
                      'hs.RunScript("Seasons.vb",True,True)'Determine the Start of each seson for the current year.
                      'JLG - 5/23/2019
                      'Create the global variables needed
                      '7-3-2019 Add Watering Global variables.
                      errst = hs.CreateVar("zntime")
                      errst = hs.CreateVar("znflwrtime")
                      errst = hs.CreateVar("soakcycles")
                      errst = hs.CreateVar("Instances")
                      errst = hs.SaveVar("zntime",ZoneTime)
                      errst = hs.SaveVar("znflwrtime",FlowerTime)
                      errst = hs.SaveVar("soakcycles",sCycles)
                      errst = hs.SaveVar("Instances", "Initialization")
                      End Sub
                      Hope this helps
                        Here is the file
                        IMPORTS System.IO
                        IMPORTS System.net
                        Dim errst
                        'Convert to string
                        hs.WaitSecs(1)
                        Do
                        hs.WaitSecs(1)
                        Else
                        Exit Do
                        End If
                        End If
                        'If port  "80" Then
                        'End If
                        'JLG - 5/23/2019
                        End Sub
                        Hope this helps
                        Thank you !!!
