Script Error
    Script Error
    Hey guys,
    Can anyone help me out with a simple fix? I copied a script from somewhere in this forum, and made it part of an event, but when the event runs I get an error.
    Here is the script:
    Sub Main()
    Dim strName As String
    Dim intR As Integer
    strName = "8.8.8.8"
    intR = hs.Ping(strName)
    If intR = 0 Then
    hs.WriteLog ("Internet", "OK")
    Else
    hs.WriteLogEx ("Internet", "?? ","#49595")
    hs.msgbox "Internet is down"
    hs.Speak ("Warning: Internet is Down. Repeat, Internet is Down", TRUE)
    End If
    End Sub
    ...and here is the error:
    Running script, script run or compile error in file: C:/Program Files (x86)/HomeSeer HS3/scripts/InternetDown.txt1025:Expected end of statement in line 3 More info: Expected end of statement
    There was a time when I could have figured this out myself, but I'm so confused between all the scripting languages. Does it have something to do with the file extension, *.txt, and it's not expecting *.vbs parameters or something?
    Jim Speiser
    Still don't know squat
    Can't have blank lines, all blank lines have to start with a accent mark ' to be a comment. It can be a blank comment but no really blank lines.
    Either remove the blank lines or put a ' in the 1st column
      I also run something similar to this but in addition if the internet is down it also reboots my router and wireless, which can sometimes be a problem. It runs once an hour and is great to fix problems and you do not have to be home.
      Stuart
        You do need to make your subroutine's declare statement match what HS is expecting. Try this:
        Sub Main(parms As Object)
        You do not need to do anything else with parms, unless you want to process some input parameters.
          Not sure where you got that from. Of course spaces are allowed!
          Originally posted by JimSpy View Post
          Hey guys,
          Here is the script:
          Sub Main()
          Dim intR As Integer
          strName = "8.8.8.8"
          If intR = 0 Then
          Else
          End If
          End Sub
          You are trying to run a VB Script (using the .txt extension) when the script contains VB.NET scripting components (such as Dim strName As String). hs.Msgbox does not also exist as a Homeseer scripting command.
          Try the following using a .vb extension (such as internetcheck.vb)
          Sub Main(ByVal parms As String)
          Dim intR As Integer
          strName = "8.8.8.8"
          intR = hs.ping(strName)
          If intR = 0 Then
              hs.WriteLog("Internet", "OK")
          Else
              hs.WriteLogEx("Internet", "?? ", "#49595")
              hs.Speak("Warning: Internet is Down. Repeat, Internet is Down", True)
          End If
          End Sub
          Jon
            I missed that the script file had the incorrect extension, and the msgbox call. Oops.
            BTW - I prefer to use "object" rather than "string" for the input parameter declare. That way I can call the same script from HS Touch, which passes parameters as a string array instead of a single string. An object can take both, so handles a call from either side without getting a parameter mismatch error. If I am processing the input parameter(s), I just check to see what type parms is, and handle accordingly within the script.
              First I've heard that. But maybe they've changed the rules....
              Jim Speiser
                Stuart
                It's almost never our router (Gryphon) or our modem (Arris), it's our alleged provider, SuddenStink. If a squirrel isn't chewing on our T1, a wildfire is melting some fiber optic cable. Or they just decide to give their servers a rest or something. This is why I have the thing run every 5 minutes, so I can get right on the phone and bitch them out.
                Jim Speiser
                  Dim intR As Integer
                  strName = "8.8.8.8"
                  If intR = 0 Then
                  Else
                  End If
                  End Sub
                  Thanks, Jon, I will give this a shot.
                  But, but, but...I have used MsgBox before, does it only work in immediate mode or something? Maybe that's where I remember using it...
                  Jim Speiser
                    That would be msgbox("Internet is down") not hs.msgbox
                    I don't recommend using it as you have to be on the same PC as HS is running (Windows only BTW) and blocks the script from running any further if it is not acknowledged.
                    Jon
                      Right. OK. Sure.
                      But...But...But...why just msgbox, isn't that an HS-unique function? I mean, it has the ability to read in global variables, and present them in the msgbox, right? So it has to access the HS API? Isn't that the criteria for putting hs.* before a function?
                      Jim Speiser
                        MsgBox is a windows API call, not an HS call. (It may also exist in the linux world, don't know.) So it works in your script, but like said above, it would only display on the PC the HS Server is running on. "hs.MsgBox" does not exist.
                          Hmmm. Processing. Analyzing. Absorbing.
                          Jim Speiser
                            One thing to remember is that the VB .net script is compiled by the regular VB .net compiler, but Homeseer does things to the script before passing it to the compiler, so that the code will work in the Homeseer environment. One of those things is to supply the compiler with the Homeseer unique routines (or API), and those routines will have that "hs." prefix.
                            So you do need to keep in mind that some things are unique to the Homeseer environment, and the rest is just standard VB .net.
