Hello,
I am getting an error with tenScriptAid during startup. Here is the contents of the popup box:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: An entry with the same key already exists.
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.SortedList`2.Add(TKey key, TValue value)
at tenScriptAid.frmMain.ConnectToHs()
at tenScriptAid.frmMain.tmrStartup_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message & m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.3928.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
tenScriptAid
Assembly Version: 1.39.0.0
Win32 Version: 1.39.0.0
CodeBase: file:///C:/Users/Patrick/Downloads/tenScriptAid_1_39/tenScriptAid.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.3761.0 built by: NET48REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3761.0 built by: NET48REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
HomeSeerAPI
Assembly Version: 1.0.2.1
Win32 Version: 1.0.2.1
CodeBase: file:///C:/Users/Patrick/Downloads/tenScriptAid_1_39/HomeSeerAPI.DLL
System.Data
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Deployment
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Scheduler
Assembly Version: 3.0.0.0
Win32 Version: 3.0.0.548
CodeBase: file:///C:/Users/Patrick/Downloads/tenScriptAid_1_39/Scheduler.DLL
HSCF
Assembly Version: 1.0.0.2
Win32 Version: 1.0.0.3
CodeBase: file:///C:/Users/Patrick/Downloads/tenScriptAid_1_39/HSCF.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
tenScriptAid
System
System.Core
System.Drawing
System.Xml
HomeSeerAPI
System.Data
System.Deployment
Scheduler
HSCF
enabled.
For example:
<configuration>
</configuration>
