I am monitoring my cistern fill with an ultrasonic sensor. That data is fed into HS via a MQTT upload. That works as it should, but the ultrasonic sensor sometimes sends false readings. I have written a script in Homeseer that runs every 2 minutes to get the data from the MQTT variable and compare it to the last reading. If the reading changed by more than 4 it should ignore it. I have since added if it is a negative number or 0 to ignore it.
I am at a loss because I am still getting false readings taken as a good reading and it messes up the whole system.
As an example lets say the reading that was good was 74. So PreviousCisternLevel is 74. A false reading comes in at 115. I am not sure why it is being allowed passed the first if statement:
Here is the complete script:
I have been fighting with this for weeks now. It runs great for days and then for some reason allows a number like 114 through when there is no way in my mind it should. PLEASE HELP!!!!
What am I missing
Dim CurrentCisternLevel As Integer = hs.DeviceValue(854) '<-- Current state of Cistern Dim PreviousCisternLevel As Integer = hs.DeviceValue(859) '<--Previous Reported Level Dim FalseReading As Integer hs.WriteLog("Cistern Reading", "Confirming reading was reset to " & PreviousCisternLevel) '<-- To start, compare previous reported with current report. If greater than just a couple point then trow away as it is more than likley a false reading [COLOR=#c0392b] if (CurrentCisternLevel >= PreviousCisternLevel +4 And CurrentCisternLevel >= 0 And CurrentCisternLevel < 105) Then[/COLOR] FalseReading = 1 hs.WriteLog("Cistern Reading", "False reading on the cistern was ignored. Current is: " & CurrentCisternLevel & " and previous was " & PreviousCisternLevel)
Public Sub Main(ByVal Parms As Object) Dim CurrentCisternLevel As Integer = hs.DeviceValue(854) '<-- Current state of Cistern Dim PreviousCisternLevel As Integer = hs.DeviceValue(859) '<--Previous Reported Level Dim FalseReading As Integer hs.WriteLog("Cistern Reading", "Confirming reading was reset to " & PreviousCisternLevel) '<-- To start, compare previous reported with current report. If greater than just a couple point then trow away as it is more than likley a false reading if (CurrentCisternLevel >= PreviousCisternLevel +4 And CurrentCisternLevel >= 0 And CurrentCisternLevel < 105) Then FalseReading = 1 hs.WriteLog("Cistern Reading", "False reading on the cistern was ignored. Current is: " & CurrentCisternLevel & " and previous was " & PreviousCisternLevel) Else FalseReading = 0 'Reading is real so assign as previous for next loop hs.SetDeviceValueByName("Cistern Level - Previous", CurrentCisternLevel) hs.SetDeviceString(859, CurrentCisternLevel, True) '<-- Cistern Full so set virtual fill valve to off if ( CurrentCisternLevel >= 100) Then hs.SetDeviceString(857, "Full", True) '<-Set Cistern Status to full hs.SetDeviceValueByName("Cistern Fill Status", 100) '<-Set Fill Status to full hs.WriteLog("Cistern Fill Level", "The current cistern level is being reported as FULL at " & CurrentCisternLevel) elseif ( CurrentCisternLevel <= 80 And CurrentCisternLevel >= 51) Then hs.SetDeviceString(857, "Fill Needed", True) '<-Set Cistern Status to Needs fill tonight hs.SetDeviceValueByName("Cistern Fill Status", 50) '<-Set Fill Status to Needs Fill tonoght hs.WriteLog("Cistern Fill Level", "The current cistern level is being reported as Less Than 80 at " & CurrentCisternLevel) elseif ( CurrentCisternLevel <= 30 ) Then hs.SetDeviceString(857, "Fill Now", True) '<-Set Cistern Status to Needs fill NOW hs.SetDeviceValueByName("Cistern Fill Status", 0) '<-Set Fill Status to Needs Fill NOW hs.WriteLog("Cistern Fill Level", "The current cistern level is being reported as Less Than 50 at " & CurrentCisternLevel) End If '<-- Set up the proper level indicator if ( CurrentCisternLevel >= 100) Then hs.SetDeviceValueByName("Cistern Level", 100) '<-Set Fill Status to full hs.SetDeviceString(858, 100, True) '<-Set Cistern Status to full elseif ( CurrentCisternLevel <= 99 And CurrentCisternLevel >= 75) Then hs.SetDeviceValueByName("Cistern Level", 75) '<-Set Fill Status to 3/4 hs.SetDeviceString(858, 75, True) '<-Set Cistern Status to 3/4 elseif ( CurrentCisternLevel <= 74 And CurrentCisternLevel >= 50) Then hs.SetDeviceValueByName("Cistern Level", 50) '<-Set Fill Status to 1/2 hs.SetDeviceString(858, 50, True) '<-Set Cistern Status to 1/2 elseif ( CurrentCisternLevel <= 49 And CurrentCisternLevel >= 25) Then hs.SetDeviceValueByName("Cistern Level", 25) '<-Set Fill Status to 1/4 hs.SetDeviceString(858, 25, True) '<-Set Cistern Status to 1/4 elseif ( CurrentCisternLevel <= 24 And CurrentCisternLevel >= 5) Then hs.SetDeviceValueByName("Cistern Level", 0) '<-Set Fill Status to low hs.SetDeviceString(858, 0, True) '<-Set Cistern Status to low End If End If 'End Checking for false reading end Sub
What am I missing
