Does entry point Main exist in script?
    Hi.
    I have a VB script that grabs a battery level from HSTouch devices. I believe it was OK in HS3, but now in HS4 I get an error in the startup log. Any ideas?
    Thank you
    Br,
    Dali
    'HS4 Script 2020-11-02 JG
    'Modified by SER 2020-11-6
    Sub Main(ByVal parm As Object)
    Dim BattLevel
    BattLevel = parm(0).ToString ' Get string from HSTouch
    hs.SetDeviceValueByRef(2266, BattLevel, True)
    hs.SetDeviceValueEx(2266, BattLevel, True)
    ' hs.writelog("HSTouch", Zipcode + " Battery Level changed to: " + BattLevel & "%")
    ' hs.writelog("HSTouch", "Client Name: " & Zipcode)
    ' hs.writelog("HSTouch", "Battery Level changed to: " & BattLevel & "%")
    End Sub
    Log
    Click image for larger version  Name:	entry point.jpg Views:	0 Size:	23.9 KB ID:	1491032
    Remove the line:
    This is an invalid scripting command.
    Jon
      It did the job!
      Thank you so much!
      Br,
      Dali
