Hi,
I'm using a script and I'm trying to speak some variable values that are locally declared.
All I want to do is insert the variable mid sentence, but I'm not sure of the correct formatting.
I've searched high and low, but everything I've found references replacement / built-in variables.
For example, this doesn't work, it probably won't anyway as it's parsed within quotes, but this is what I'm after.
Dim DeviceName As String = Washer hs.speak("The $$DeviceName is switched off")
Thank you
