Compiling script C:\PROGRAM FILES (X86)\HOMESEER HS3\scripts
    Moved from HS3 Linux to HS3 windows. After that I will move to HS4 windows. Doing the upgrade in steps for minimal loss of service. So far so good. Looks like everything is back except some custom scripts I had in the Linux box no longer work in the windows environment. Here is the script. I stole from the forms it years back when I first started with HS and modified it slightly for my needs. It is a simple countdown script for my gate hold open timer.
    Sub Main(ByVal pram as Object)
    Dim StartVar as string ' Set this to the countdown starting value
    Dim pram as string
    Dim test as string
    'test = hs.CAPIGetStatus(18).Value
    'hs.writelog("Value", + test)
    pram = hs.CAPIGetStatus(18).Value
    If pram = 300 then
    pram = 3600
    End if
    If pram = 400 then
    pram = 7200
    End if
    If pram = 500 then
    pram = 10800
    End if
    IF pram = 600 then
    pram = 180
    End if
    'IF pram = 600 then
    'pram = 2
    'End if
    StartVar = pram
    Dim x as Integer
    'hs.writelog("StartTime", + StartVar)
    'hs.writelog("pram ", + pram )
    x = Convert.ToInt32(hs.TimerValue("GATE HOLD").TotalSeconds)
    'hs.writelog("X", + x)
    'hs.SetDeviceValueByRef(16, StartVar - x, True)
    'hs.SetDeviceString(16, StartVar - x & " seconds", True)
    'hs.writelog("Utility Countdown","Updating")
    Dim hms as TimeSpan = TimeSpan.FromSeconds(StartVar - x)
    Dim h = hms.Hours.ToString
    Dim m = hms.Minutes.ToString
    Dim s = hms.Seconds.ToString
    hs.SetDeviceString(197, h & ":" & m & ":" & s, True)
    'hs.SetDeviceString(16, m & " min " & s & " sec", True)
    hs.SetDeviceValueByRef(197, StartVar - x, True)
    'hs.SetDeviceString(18, h & ":" & m & ":" & s, True)
    ' hs.SetDeviceValueByRef(18, StartVar - x, True)
    If x >= StartVar then
    hs.WaitSecs(1)
    hs.SetDeviceValueByRef(197, StartVar, True)
    'hs.SetDeviceString(16, StartVar & " seconds", True)
    hs.SetDeviceValueByRef(18, 0, True) 'Set to Close
    hs.SetDeviceString(197, 0, True)
    'hs.SetDeviceString(18, 0, True)
    'hs.SetDeviceString(18, "", True) ' Fix for Bad Device String
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(97, true, "Off", false, true))
    hs.WaitSecs(2)
    End If
    End Sub
    Andy
    How are you calling the script? Do you see anything in the logs?
      Through and event action. That is what I see in the event log... The Compile script error.
        Try removing (comment out) the third line "Dim pram as string", OR change the "pram" parameter name in the first line to something else.
        Declaring "pram" twice will cause an error.
          Take a look at tenholde's tenscripting for HS4. The error is flagged in the VS environment. I suspect the Mono compiler for Linux is more forgiving.
            http://tenholder.net/tenWare2/tenScripting/default.aspx
            tenholde
              That worked removed line 3 and no issues.
              Thanks much for the help.
