Problem with script errors
    Hi,
    I'm trying to get some code working that @deloosem​ has created to send raw zwave commands to his radiator valve.
    But everytime I run it I get some errors:
    Script:
    Public Sub Main(ByVal Parms As Object)
    Dim Bytes = New Byte() = {&H31, &H5, &H1, &H42, &H8, &HBE} ' transmits 22.38 c°
    hs.PluginFunction("Z-Wave", "", "SendZwaveRaw", New Object() {18, Bytes, Bytes.Length, False, "3dh76whs83"})
    End Sub
    Errors:
    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\simplescript.vb: 'Bytes' is not declared. It may be inaccessible due to its protection level.
    Jan-05 11:11:58         Error    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\simplescript.vb: 'Bytes' is not declared. It may be inaccessible due to its protection level.
    Jan-05 11:11:58         Error    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\simplescript.vb: '}' expected.
    Jan-05 11:11:58         Error    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\simplescript.vb: Declaration expected.
    Jan-05 11:11:58         Error    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\simplescript.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    If anyone can help?
    I think "Bytes" could be a reserved word. Try Dim B = New Byte().... (or some other name).
      Thanks, I tried that but the same errors persist.
      Not sure why it worked for the other chap.
        I'm just beginning to learn this stuff, but I think "Dim Bytes = New Byte()" should be "Dim Bytes As New Byte()"
        HomeSeer Version: HS4 Pro Edition 4.2.18.1
        Operating System: Microsoft Windows 10 Pro - Desktop
        Z-Wave Devices via two Z-Net G3s
        Zigbee Devices via RaspBee on RPi 3b+
        WiFi Devices via Internal Router.
        Enabled Plug-Ins
        AK Weather 4.0.5.37,AmbientWeather 3.0.1.9,Big6 3.34.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 3.3.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 3.30.1003.1,JowiHue 4.0.8.7,LG ThinQ 4.0.24.0,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.4,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 3.0.11.0 2
          Just tried that, sadly the same error occurs.
          think I'm missing something obvious but not sure what.
            That is my problem with working with multiple languages at the same time.
            The proper syntax is:
            Dim b as Byte
            Dim buffer(1024) As Byte
            https://learn.microsoft.com/en-us/do...byte-data-type
            Still suggest staying aware from using "bytes" as a variable name, too close to a reserve word (and can cause problems).
              Try
                      Dim bytes() As Byte = {&H31, &H5, &H1, &H42, &H8, &HBE}​
                That appears to satisfy VS, but apparently, in the next line byte.Length is a no-no.
                Enabled Plug-Ins
                  His next line is "Bytes.Length", (plural), which is correct.
                    Yeah, my bad, I forgot I had changed it to "b" so it wouldn't be so close to Byte.
                    Enabled Plug-Ins
                      Try
                      Think I tried that, but not sure now.
                      This I think works, but not sure yet.
                      Does this look right?
                      Dim B As Byte() = New Byte() {0x71, 0x06, 0x01, 0xFF}
                        No that generates a syntax error.
                          Strange because on my system that doesn't complain.
                          Nor does this:
                          Dim B() As Byte = {&H71, &H06, &H01, &HFF}
                            Nor does this:
                            That's the syntax I posted earlier. This declares an array of bytes and initializes it from the given list.
                              Yes, sorry, that's what I meant.
                              Okay.
                              The original script which 'apparently' works has it has :
                              Is that doing the same thing?
