No it does noticeably step up. I think this is down to zwave only allowing for every 5 values so 1, 2, 3, 4, 5 are all the same. That said its only really noticeable if you watch it.
Good to know. Knowing that, I'd notice it and it would bug the heck out of me
________________________
Dell Zino HD - HSPRo 2.x
HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
2 x Brultech ECM1240 with UltraECM
USB UIRT
Cooper Aspire Z-Wave Switches
WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
HM ST812-2 Flood Sensor
HSM100 - Motion Detector with Light and Temperature
2GIG Thermostat
BLDSC - Alarm Plug-in
BLUPS
UltraLog (SQL2008)
Jon00 Plugins
Host XR3 BT and Jon00 BT Proximity
Global Cache IP2IR
Foscam FI8918W
Thankyou,
AquaCom for uploading the script, must admit it looks a bit daunting for me but will try and figure it out when I get my HS3 machine up and running again. The hard disk crashed, so decided to build a new machine with a bit more oomph.
Thanks again
Peter
