random file selection
    greetings,
    i thought i was a good vb programmer until i tried to write a script in homeseer.
    i just want to grab an array of the files in a given directory, select one at random and copy it to the html directory.
    (yes, this is for HStouch to use as a slide show)
    everything i've tried i've ended up with one error or another, i'm lost, and ready to increase my alcohol consumption
    thanks
    In the weatherXML plugin I use vb.nets directoryInfo and fileInfo to get a list of all the script files in the HS script directory to build a dropdown.
    PHP Code:
    Dim di As DirectoryInfo
    Dim diar1
    As FileInfo()
    Dim dra As FileInfo
    di
    = New IO.DirectoryInfo(fullPathway to your directory)
    diar1 di.GetFiles()
    dd = New clsJQuery.jqDropList(sDdNamepageNameFalse)
    dd.AddItem("No Script"""sSel "")
    For
    Each dra In diar1
    If dra.Extension.ToLower ".vb" Or dra.Extension.ToLower ".txt" Then
    dd
    .AddItem(dra.Namedra.Namedra.Name sSel.Trim)
    End If
    Next
    s
    .Append(dd.Build
    You should be able to modify this and use diar1 as your array.. Once you have a random picture selected you can use File.Copy to copy it to the html directory.
    Jeff Farmer
    HS 3, HSPhone
      errors out....
      imports system.io
      sub main
          hs.WriteLog "Error", "Hello World"
          sourcedir= "E:\Source\hs3\pics"
      Dim diar1 As FileInfo()
      Dim dra As FileInfo
      di = New IO.DirectoryInfo(sourcedir)
      diar1 = di.GetFiles()
      dd = New clsJQuery.jqDropList(sDdName, pageName, False)
      dd.AddItem("No Script", "", sSel = "")
      dir_count = 0
      For Each dra In diar1
      If dra.Extension.ToLower = ".png" Or dra.Extension.ToLower = ".jpg" Then
      dir_count = dir_count + 1
      dd.AddItem(dra.Name, dra.Name, dra.Name = sSel.Trim)
      End If
      Next
      s.Append(dd.Build)
      hs.WriteLog "Error", "Number of files: " & dir_count
      end sub
      error
      Expected end of statement in line 7 More info: Expected end of statement
        I have only been working in plugins but clsjquery items needs the following
        Imports Scheduler
        but with what you are wanting to do you can remove the dropdown and just use the array.
        PHP Code:
        di = New IO.DirectoryInfo(fullPathway to your directory
        diar1 di.GetFiles()
        Dim nFiles As Int16 diar1.GetUpperBound(0)
        ' Get your random number.
        Dim filename as string = diar1(rndNumber).ToString
        That should give you what you said you are wanting. An array of the files. nFiles should give you the number of files in the directory.
        Select a number between 0 and nFiles
        You can then use File.Copy to move the random file.
        Make sure that you replace
        with some code that gets a random number between 0 and nFiles
        Jeff Farmer
        HS 3, HSPhone
          seems to be causing the error, not sure why?!?! i'm importing system.io
