Stop a running script...?
    The HS2 version of my sunshine alarm clock was pretty easy. Just a simple timer that increased the device value at a given interval. You can find it here:
    http://board.homeseer.com/showpost.p...4&postcount=30
    I'm learning HS3 scripting (and plugin writing) so I'm converting my old scripts to HS3.
    HS2 would only run one instance of the above mentioned script, meaning to stop it I could just call the Main sub again with a different parameter (to run it for another room, I had to make duplicates of the script).
    However, that doesn't work anymore. So, how can I now terminate a running script?
    Hi Moskus,
    I would set up a virtual device with two possible values: run and stop. Have your script check the value in its loop and if the value has changed to stop then terminate the script.
    Cheers
    Al
      Originally posted by sparkman View Post
      Hi Moskus,
      Cheers
      Al
      Yes, that's the solution I can think of too (or use a Global Variable), but I would suspect there is another way. It should be possible to do it using code.
