Status Change Script
  • Status Change Script
    Trying to convert this script from HS2-HS3 that captures device changes to a virtual device. I have this script references in the startup.vb but the virtual device (v10) is not updating. I suspect it has to do with how the devices are referenced now?
    hs.writelog("Callback", "Registering for status change callback...")
    hs.RegisterStatusChangeCB("callback.vb", "Callback")
    End Sub
    Sub Unregister(ByVal Parms As Object)
    hs.writelog("Callback", "Unregistering for status change callback...")
    hs.UnRegisterStatusChangeCB
    End Sub
    Sub Callback(ByVal Parms As Object)
    Dim DCheck() As String ={"N1", "N3", "N5", "N7", "O1", "O3", "O5", "O7", "O9", "O11", "O13", "O15"}
    Dim DevStr As String = "V10" 'virtual device to update
    For Each s As String In DCheck
    If Parms(0) & Parms(1) = s Then
    hs.writelog("Callback", "In the array...")
    If Parms(2) = 2 Then
    hs.writelog("Callback", "Device: " & Parms(0) & Parms(1) & " has turned on")
    'hs.setdevicestring(DevStr, hs.devicestringbyname(Parms(0) & Parms(1)), True)
    hs.setdevicestring (DevStr, hs.getdevicebyref(parms(3)).location, True)
    End If
    End If
    Next
    End Sub
    I have a feeling I might have written that script (?), anyway a few changes need to be made to this script to get it to work again. This is a pointer as I don't use HS3 in reality so can't test it, I would guess at the following
    If Parms(0).ToString = s Then
    If Convert.ToDouble(Parms(2)) = 100 Then 'I am guessing that 100 is on, could be different
    hs.writelog("Callback", "Device: " & Parms(0).ToString & " has turned on")
    hs.setdevicestring(1234, hs.getdevicebyref(parms(4)).location(hs), True) 'change first parameter to reference rather than code
    End If
    End If
    Next
    End Sub
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      Indeed this is your script! Question, I assume I still would need this at the top if I have it referenced in the startup.vb?
      End Sub
      End Sub
        End Sub
        End Sub
        Yep you still need those, both of the functions look to be broadly the same http://homeseer.com/support/homeseer...uschangecb.htm however what is returned is slightly different which means the callback script will change. Based on what the help file says I have made some amendments which I think might work.
        My Plugins:
