Does hs.SendToComPort work or is it only me?
  • Does hs.SendToComPort work or is it only me?
    I'm trying to control the HDMI switch (from Monoprice). This is the exact same script as in HS2:
    Sub Main(parm as object)
    hs.OpenComPort(5,"4800,n,8,1",1,"","")
    hs.WaitSecs(1)
    hs.sendtocomport(5, parm.tostring & vbCrLf)
    hs.WaitSecs(1)
    hs.CloseComPort(5)
    End Sub
    (for example, calling sub "Main" with parameter "OFF").
    And this worked without problems in HS2. The same methods with the same arguments exist in HS3, but I get no reaction from the switch.
    What gives?
    Fixed?
    hs.WaitSecs(1)
    hs.WaitSecs(1)
    hs.CloseComPort(5)
    End Sub
    What gives?
    Did you ever get this figured out?
      No...
        Here's a script I used to use in HS3 to control my monoprice amp. (before the plugin) Maybe something useful in it.
        'Send Parameters in the form target|command|value ie. z1|volume|20
        'targets: a1,a2,a3, z1,z2,z3,z4,z5,z6,z7,z8,z9,z10,z11,z12,z13,z14,z15,z16,z17,z18.
        'commands: power,volume, mute, dnd(do not disturb),balance, treble, bass, source.
        'value: on, off, volume 00-38, treble/base 00-14, balance 00-20
        'Don't forget to set the com port
        Imports System.Threading
        Imports System.IO.Ports
        Imports System.Object
        Imports System.Text
        Public COMPort As New SerialPort()
        Public Sub Main(ByVal parm as Object)
        Dim tcArray(2) As String
        tcArray = parm.ToString.Split("|")
        Dim target As String = tcArray(0)
        Dim command As String = tcArray(1)
        Dim value As String = tcArray(2)
        hs.writelog("Monoprice Amp", "Script called with: "& target & "|" & command & "|" & value)
        Dim tcString = "" 'this is what will eventually be sent to the com port
        Dim tcStringBuilder As New StringBuilder("<") 'start building tcString
        Select Case target           'Select Target
        Case "a1"
        tcStringBuilder.Append ("10")
        Case "a2"
        tcStringBuilder.Append ("20")
        Case "a3"
        tcStringBuilder.Append ("30")
        Case "z1"
        tcStringBuilder.Append ("11")
        Case "z2"
        tcStringBuilder.Append ("12")
        Case "z3"
        tcStringBuilder.Append ("13")
        Case "z4"
        tcStringBuilder.Append ("14")
        Case "z5"
        tcStringBuilder.Append ("15")
        Case "z6"
        tcStringBuilder.Append ("16")
        Case "z7"
        tcStringBuilder.Append ("21")
        Case "z8"
        tcStringBuilder.Append ("22")
        Case "z9"
        tcStringBuilder.Append ("23")
        Case "z10"
        tcStringBuilder.Append ("24")
        Case "z11"
        tcStringBuilder.Append ("25")
        Case "z12"
        tcStringBuilder.Append ("26")
        Case "z13"
        tcStringBuilder.Append ("31")
        Case "z14"
        tcStringBuilder.Append ("32")
        Case "z15"
        tcStringBuilder.Append ("33")
        Case "z16"
        tcStringBuilder.Append ("34")
        Case "z17"
        tcStringBuilder.Append ("35")
        Case "z18"
        tcStringBuilder.Append ("36")
        Case Else
        hs.writelog("Monoprice Amp", "Target not found: " & target)
        End Select
        Select Case command
        Case "power"
        tcStringBuilder.Append ("PR")
        Case "mute"
        tcStringBuilder.Append ("MU")
        Case "volume"
        tcStringBuilder.Append ("VO")
        Case "dnd"
        tcStringBuilder.Append ("DT")
        Case "treble"
        tcStringBuilder.Append ("TR")
        Case "bass"
        tcStringBuilder.Append ("BS")
        Case "balance"
        tcStringBuilder.Append ("BL")
        Case "source"
        tcStringBuilder.Append ("CH")
        Case Else
        hs.writelog("Monoprice Amp", "Command not found: " & command)
        End Select
        Select Case value
        Case "on"
        tcStringBuilder.Append ("01")
        case "off"
        tcStringBuilder.Append ("00")
        Case Else
        tcStringBuilder.Append (value)
        End Select
        tcString = tcStringBuilder.ToString()
        Dim Com as Object
        Dim rxBuff as String
        rxBuff = ""
        COMPort.PortName = "COM5"
        COMPort.BaudRate = 9600
        COMPort.Parity = System.IO.Ports.Parity.None
        COMPort.DataBits = 8
        COMPort.StopBits = System.IO.Ports.StopBits.One
        Comport.ReadTimeout = 1000
        If COMPort.IsOpen = False Then
         COMPort.Open()
        End If
        Com = tcString & vbCr
        hs.writelog("Audio", "Sending: " & Com)
        COMPort.Write(Com)
        System.Threading.Thread.Sleep(600)
        'Reading the com port:
        rxBuff = (COMPort.ReadExisting)
        If rxBuff <> "" Then
        hs.writelog("Audio", "Received:" & rxBuff)
        rxBuff = ""
        End If
        COMPort.close()
        End Sub
        If it ain't broke, don't fix it!
          hs.WaitSecs(1)
          hs.WaitSecs(1)
          hs.CloseComPort(5)
          End Sub
          What gives?
          Your script would probably work if you allowed more time for the com port to open. 1 second is way too short. 5-10 seconds is more realistic. Once the port is open, leave it open. No need to reopen it each time you send a command.
          I use sendtocomport a lot in HS3. I use a one line immediate script.
          Steve Q
            Hmmm! That might be it! I haven't even thought about that.
            But I scraped that Monoprice HDMI switch a couple of years ago...
