I want to create an event, have it run with a time trigger and then delete itself. I have this running in HS2.
After spending quite a bit of time with the documentation, I can now create an event, set the trigger type to time and add a device action. I need to set the event option to "remove this event after triggering". I can't find a function that will allow me to modify the event options. Hopefully this is an oversight in the docs and a function is provided to modify this option.
If nothing is available, I need a "work around" to achieve this functionality.
