Reference to a non-shared member requires an object reference.
  • Reference to a non-shared member requires an object reference.
    I'm trying to convert my HS2 telephone script to HS3, but get multiple errors stating
    Compiling script D:\HomeSeer HS3\scripts\CID_in_V01.vb: Reference to a non-shared member requires an object reference.
    Can someone point me to what needs to change for HS3?
    dim cname
    dim cnumber
    Dim I As Integer
    Dim AddrBkIndex As Integer
    Dim intAdrCount As Integer = hsp.ADRCount
    Dim objContact As Scheduler.clsContact
    Dim strName As String
    Dim strAdrName As String
    Dim strNumber As String = ""
    Dim strAnnounce As String
    Dim CT_CIDFLAGS_BLOCKED as Boolean
    Dim Byte1, Byte2 As Byte
    Dim MyByte, MyBit
    cname = hs.LastCallerInfo(1)
    AddrBkIndex = 0					'
    '*** Send to HSTouch ***
    	hs.writelog("CIDNumber", "Script CID: " & hsp.cidnumber(1))
    	hs.setdevicestring("Z4", MkPhoneNum(hsp.cidnumber(1)), True)
          hs.SetDeviceLastChange("Z4", Now)
    	hs.writelog("CIDName", "Script CID name: " & hsp.cidname(1))
          hs.setdevicestring("Z3", cname, True)
          hs.SetDeviceLastChange("Z3", Now)
    	hs.writelog("CIDName", "Script last-caller name: " & cname)
          hs.setdevicestring("Z5", " ", True)
          hs.SetDeviceLastChange("Z5", Now)
    '**  HSP.HIPSendLocalCID(1,cname, hsp.cidnumber(1))
    strName = hsp.CIDName(1)
    strNumber = hsp.CIDNumber(1)
    If strNumber.Length > 3 Then
    	strNumber = strNumber.Substring(0, 3) & "-" & strNumber.Substring(3, 3) & "-" & strNumber.Substring(strNumber.Length - 4)
    End If
    hs.writelog("LookFor", strName & "  " & strNumber)
    For I = 1 to intAdrCount            'Search the address book for a match
       objContact = hsp.ADRGet(I)
    	'  hs.WriteLog "AdrEntry1", CStr(I) & " - " & objContact.FIRST & " " & objContact.LAST & " - " & objContact.cid_group_category
    	'  hs.writelog("AdrEntry2", "Cell: " & objContact.cell_phone & "  Home: " & objContact.home_phone )
    	'** if the phone number or the CID Name matches
       	If objContact.cell_phone = strNumber OR objContact.home_phone = strNumber OR objContact.business_phone = strNumber OR objContact.cid_name = strName Then
    		'** save index of the match
    		AddrBkIndex = I
    		'** test the "blocked" flag - if false, send CID info to phones
    		CT_CIDFLAGS_BLOCKED  = FALSE   'reset flag prior to testing
    		CT_CIDFLAGS_BLOCKED  = ExamineBit(objContact.CIDFLAGS, 1)
    		If CT_CIDFLAGS_BLOCKED  = FALSE
    		End if
    		If CT_CIDFLAGS_BLOCKED  = TRUE
    			hs.setdevicestring("Z5", "Blocked", True)
    		End if
    		hs.WriteLog("AdrMatch", CStr(I) & " - " & strNumber & " " & objContact.cid_name)    ' Match found
                strAdrName = objContact.FIRST & " " & objContact.LAST
                strName = strAdrName
    		'** special processing for entries marked as Family
    		'If objContact.cid_group_category = "Family" Then
                 '   HSP.HIPSendLocalCID(1,cname, hsp.cidnumber(1))
                 '  strAnnounce = objContact.announce_local_wav
                 '   hs.WriteLog("AdrMatchF", strAdrName)
                   '     hs.Run("StartGeneralAnnounce.vb")
                   '     hsp.WaitMS(100)
                   '     hs.Speak(strAnnounce, True)
                   '     hs.WaitSecs(1)
                   '     hs.Speak(strName, True)
                   '     hsp.WaitMS(100)
                   '     hs.Run("RestoreRussoundGeneral.vb")
               ' End If
               I = intAdrCount
          End If
        Next
    '** if no match found in address book, index will be zero.  If so, send CID info to phones
    If AddrBkIndex = 0
    	hs.WriteLog("AdrMatch", CStr(I) & " No match found")    ' No match found
    End if
    End Sub
    Private Function MkPhoneNum(byVal number)
    Dim tmp
        number = CStr( number)
        number = Trim( number)
        number = Replace( number, " ", "" )
        number = Replace( number, "-", "" )
        number = Replace( number, "(", "" )
        number = Replace( number, ")", "" )
        Select Case Len( number )
           Case 7
              tmp = tmp & Mid( number, 1, 3 ) & "-"
              tmp = tmp & Mid( number, 4, 4 )
           Case 10
              tmp = tmp & "(" & Mid( number, 1, 3 ) & ") "
              tmp = tmp & Mid( number, 4, 3 ) & "-"
              tmp = tmp & Mid( number, 7, 4 )
           Case 11
                tmp = tmp & Mid( number, 1, 1 ) & " "
                tmp = tmp & "(" & Mid( number, 2, 3 ) & ") "
                tmp = tmp & Mid( number, 5, 3 ) & "-"
                tmp = tmp & Mid( number, 8, 4 )
            Case Else
                MkPhoneNum = "Invalid"
                Exit Function
        End Select
        MkPhoneNum = tmp
    End Function
    Function ExamineBit(ByVal MyByte, ByVal MyBit) As Boolean
    	Dim BitMask As Int16
    	BitMask = 2 ^ (MyBit - 1)
    	ExamineBit = ((MyByte And BitMask) > 0)
    End Function
    Fred
    HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
    Found the answer. In the function MkPhoneNum (last thing in the script), changing it from Private Function to just Function allows it to run without errors.
    Fred
