Need scripting to toggle device please
  • Need scripting to toggle device please
    With the new CAPI stuff I'm at a total lose as to how to accomplish this.
    I would like a script that can toggle a device based on it's current status.
    Example:
    I use BLControl with NFC, when I put my phone next to a NFC Sticker it can turn a device on or off. What I would like is a script that I can tell it to run that would get the device status and then do the opposite. If it's on, turn it off kind of thing.
    Basically:
    Get device status (on/off)
    if device = on then
    set device = off
    writelog "Turning device off"
    elseif device = off
    set device = on
    writelog "Turning device on"
    else
    writelog "I didn't understand status"
    end if
    I'm pretty good at modifying stuff but to start from scratch, I've got no clue.
    Thanks.
    Bryan
    Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
    Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
    Try this ists a copy from tenscripting
    PHP Code:
       Public Sub Main(ByVal Parms As String)
    Toggle the Specified Device ON/OFF
    ''   DIM is considered ON
    Specify the Device Nameincluding Locations, as a Parm
            Dim devValue
    As Double
            Dim theDevice
    As String
    '' Get Device from the Parms
            theDevice
    Parms.ToString
    '' Get the Device Status
            devValue
    hs.DeviceValueByName(theDevice)
    '' Toggle it
            Select
    Case devValue
    Case Is 0
    '' Device ON or DIMturn it OFF
                    hs
    .SetDeviceValueByName(theDevice0)
                Case
    0
    '' Device OFFturn it ON
                    hs
    .SetDeviceValueByName(theDevice100)
    End Select
        End Sub
    Scripts =
    Various
      I just got that question answered here ya go:
      http://board.homeseer.com/showthread.php?t=168359
        You guys are awesome! Thank you very much. Just in case the other post disappears over time. I'll post the code here too.
        Just use the device Reference ID as the Parameter when running this script.
        PHP Code:
        Sub Main(ByVal theDevice As String)
            Dim devValue
        As Double
            devValue
        hs.DeviceValue(theDevice)
        '' Toggle it
            Select
        Case devValue
        Case Is 0
                hs
        .CAPIControlHandler(hs.CAPIGetSingleControl(theDevice,true ,"off",false,true))
            Case
        0
                hs
        .CAPIControlHandler(hs.CAPIGetSingleControl(theDevice,true ,"on",false,true))
        End Select
        End Sub
        Thanks again!
        Bryan
