Holy cow, I got it working!
I had to go a different route, but it works! This is a heavily modified version of Rob Mason's example. I'm sure there are ways to make what I've done much more efficient, but I'm happy with it for now! I never did figure out why the other method wouldn't work, so Bob, I'm hoping this has helped you in some way at least.
Imports System.IO ''Heavily modified from Rob Mason's ZeeTemperature.vb - Thanks Rob! ''ZeeTemperature.vb - Rob Mason - 10/23/2013 - Free to use/modify. Sub Main(parm as object) dim sr as StreamReader dim wxdata as String dim lin as String dim SplitStr() As String Try sr = new StreamReader("/mnt/wxlogs/scriptlog.txt") 'directed to my weather server wxdata = sr.ReadToEnd 'read the entire file (it's only two lines) lin = Split(wxdata, VBCrLf)(1) 'read the second line of text SplitStr = Split(lin, ",") 'grab each value between the commas hs.writelog("Year", SplitStr(0)) '1st value hs.writelog("Month", SplitStr(1)) '2nd value hs.writelog("Day", SplitStr(2)) '3rd value hs.writelog("Hour", SplitStr(3)) '4th value hs.writelog("Minute", SplitStr(4)) '5th value hs.writelog("Wind", SplitStr(5)) '6th value hs.writelog("Gust", SplitStr(6)) '7th value 'etc 'these values can now be assigned to virtual devices Catch ex as Exception hs.WriteLog("WD",ex.Message) Finally if(not sr is Nothing) then sr.close() End Try End Sub
