System Status Report
    Does anyone have a script to generate a "System Status Report.
    What I have in mind is a script to generate either a text file, e-mail report or hs.speak of my system status.
    For example:
    "System Status Report Time 12:01 AM 29 August 2015
    The alarm system is armed away (faulted, ready) with zone x and zone y bypassed (open).
    All water sensors are clear.
    The indoor temperature is x degree and the humdity is x %
    The bedroom temperature is x degrees and the humidity x %
    I realize that this will need to be be individually customized but I thought I would check to see if anything was out there before I tried cobbling my own.
    Might make a great plugin?
    DSteiNeuro
    HS3Pro
    MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
    Enabled Plug-Ins
    BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
    hs.Speak script
    If you shoot me the necessary information I can cook one up that you can edit to your needs. Only catch is, it'll be in C#. I don't know VB at all and have never found the proper motivation to learn it. Do you want the output method selectable via parm or what are you thinking there? I'll need device names and I don't use any water sensors so let me know what the device values are for water/no water/faulted/ok/etc.
      Hi Joseph,
      Thanks for the very kind offer.
      I think that it would be too involved to try to port the devices that I am interested over to you and also I wouldn't be able to tweak in C#.
      I can go ahead and cobble a .net script on my own.
      This still would make a great plug in!
      DSteiNeuro
      DSteiNeuro
      HS3Pro
      Enabled Plug-Ins
