How to combine device status's into virtual device
    OK, I'm stumped. I've tried figuring this out for a couple days but I give up. This will be easy for you guys, I'm sure. So I have the main panel energy monitor, and it only shows watts for each leg separately. Though...there is one child device called "Power" that sure looks like the combined power but it never updates.
    I found the post by rmasonjr where he wrote a script to do this but it isn't working for me. Here is my script:
    And the error.
    Thanks!
    Chris
    I'm not an expert on this, and hopefully Rob will chime in. I don't know if you or I have the latest version. Mine does work.
    This is what I have.
    Sub Main(Parms as Object)
        hs.setDeviceString(166,"",True)
        hs.setDeviceString(166,(hs.deviceValue(145) +hs.deviceValue(148)) & "kWh",True)
    End Sub
    Tom
      Hi Chris - Tom has it right. Your script has a lot of extra spaces between the script command and the parens. If you will edit your script to look like Tom's and replace with your device id's you should be good to go.
      Let us know if that doesnt get it.
      68 Z-Wave Nodes, 175 Events, 359 Devices
        End Sub
        Thanks so much! Working perfect now.
          And thank you for the initial script. Unfortunately (for me) you posted a picture of your script so I couldn't just copy/paste like I normally do. I need to take some time and learn some basics of scripting. I find myself getting intimidated whenever I start trying to type one out.
            This script works great for me, however, I only get a rounded number as a string. Is there any way to:
            1) Send to the DeviceValue variable instead of a DeviceString?
            2) Show the entire decimal number from the addition of the two values, not just the rounded number?
              You will need to make sure that the device is setup correctly to accept values with value ranges wide enough for this. But it will probably be something like;
              hs.setDeviceValuebyref(166,(hs.deviceValueex(145) +hs.deviceValueex(148)),True)
              End Sub
              And in the value range you can specify the suffix as kWh
                End Sub
                Thanks!
