How to send HTTP "instruction" with HomeSeer
  • #16
    You can try a .net version of that command that should work with mono: https://msdn.microsoft.com/en-us/lib...v=vs.110).aspx. I've used it in some scripts before and can try to dig something up, but if you google "httpwebrequest", you should find quite a few samples. You may want to file a bugzilla re. hs.geturl.
    Cheers
    Al
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
    • #17
      Cheers
      Al
      Sorry to update this but after starting another thread, we determined that vbnc wasnt running and thats why no scripts were working correctly. Then determined it was an issue with the mono install. I have formatted the sd card started fresh and have the same issue right now. So I have now started a third thread trying to find out proper instructions for a fresh mono install on jessie lite for Rpi3.
      see here:
      http://board.homeseer.com/showthread...47#post1271347
      and now here:
      http://board.homeseer.com/showthread...51#post1271351
      Still trying to find the end to this problem, but seem to be getting closer. I'm now getting this error after running a script
      Oct-26 03:05:34 Error Compiling script /tmp/K1.vb: Visual Basic.Net Compiler version 0.0.0.5943 (Mono 4.0.1 - tarball) Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved. vbnc : Command line : error VBNC2017: The library 'System.Dat a.DataSetExtensions.dll' could not be found. There were 1 errors and 0 warnings. Compilation took 00:00:00.6612960
      some other post said to run install mono-complete to correct it, but It says installed and wont go anymore.
      • #18
        Big5 is a plug-in for HS3 that supports HTTP
        https://forums.homeseer.com/forum/li.../big5-risquare
