Hi guys,
First time Forum user here and in the process of setting up a new HS house.
The question I have is, how do I send a HTTP command via homeseer, that does not need to return anything back?
I have a ThinkFlood Redeye Inferred flasher which is WIFI connected and accepts HTTP commands to trigger scenes. I.e. if I open a browser and put http://192.168.0.5:8080/redeye/rooms...activityId=197 in the address line and hit enter, my TV, AMP etc all turn off. IE doesn't return anything (just a blank white page) so I don't really need a GET command I don't think. I have other HTTP commands that change the AMP input or surround settings etc that I would like to be able to trigger with events in homeseer.
Can anyone tell me what the VB command would be that I can enter into the "Execute Immediate script command" field in HomeSeer that would send this HTTP instruction? Or if that's not possible, what the VBS script might look like? I have searched the web for hours and only seem to be able to find instructions for GETUrl based scripts that I cant get to work with my limited (i.e. no existant, but hopefully soon to be learnt) knowledge of Scripting/programming etc.
One command I have managed to work out that enables another event in HomeSeer is:
&hs.enableEvent "Test Security events When Alarm is Armed"
SO I had started with something along the lines of:
&hs.GetUrl ("http://192.168.0.5:8080/redeye/rooms...activityId=197") but that doesn't work.
I've also found this thread, but have tired all mannor of combinations suggested, none of which seem to work:
http://board.homeseer.com/showthread.php?t=148059
Any Help would be much appreciated.
